Making Brackets for KZs... 12 Jan 2019 16:37 #796621
  • 650Dude
  • 650Dude's Avatar Topic Author
  • User is blocked
  • Thank you received: 19
Scirocco wrote: If you bent it right, yes
Thanks a lot. I will keep you posted on my progress
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
Making Brackets for KZs... 12 Jan 2019 16:47 #796623
  • 650Dude
  • User is blocked
I might keep the black part of the bracket that goes on the back of the tailight housing and weld it to the Aluminum piece I will make?
Making Brackets for KZs... 12 Jan 2019 18:15 #796631
  • M_a_t_t
  • M_a_t_t's Avatar
  • Thank you received: 41
Are you planning on taking it somewhere to be welded?
That plate is most likely steel, you couldn't weld the two (aluminum and steel) together if it is. I would just use some bolts to attach it to the bracket
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Making Brackets for KZs... 12 Jan 2019 18:30 #796633
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Away
  • Thank you received: 298
:whistle:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Making Brackets for KZs... 12 Jan 2019 19:32 #796635
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 379
Nebr_Rex wrote: :whistle:
Yup.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Making Brackets for KZs... 13 Jan 2019 06:11 #796662
  • 650Dude
  • User is blocked
M_a_t_t wrote: Are you planning on taking it somewhere to be welded?
You actually CAN weld steel to aluminum ( i researched it) but what Im going to do is make the entire bracket out of either steel or aluminum. Havent decided which yet.
Making Brackets for KZs... 13 Jan 2019 06:23 #796664
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 656
JBWeld doesnt count it isn't weld.
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
Rear Area Frame Differences between KZ650, KZ900 and KZ1000 13 Jan 2019 06:28 #796667
  • 650Dude
  • User is blocked
Id still like to know if the license plate to frame bracket for a 900/1000 would fit a KZ650, and what the rear frame differences are.
I dont need the tail light part and would give that away. Im only interested in the license plate to frame part.
Last edit: by 650Dude.
Rear Area Frame Differences between KZ650, KZ900 and KZ1000 13 Jan 2019 06:57 #796673
  • 650Dude
  • User is blocked
I think I found the solution. Poster RSTNICK posted back in 2010 his way of attaching the light (the same ZX6E I have) to his KZ650. Looks SUPER easy. just 2 "L" brackets!!
Making Brackets for KZs... 13 Jan 2019 09:11 #796680
  • M_a_t_t
  • M_a_t_t's Avatar
You can also weld cast iron and steel, but without lots of forethought it will crack
You can also weld stainless steel to carbon steel, but it will rust at the seam
Aluminum and steel expand and contract different. Even if you got a good weld it would crack and fall apart in the short term.
Soldering the two together would probably be a better idea or riveting. A pop rivet gun is only like 20 dollars at harbor freight.
Why wouldn't you just keep what you've found about the fender eliminator in one thread?
Edit:
Something like this:
"Fender eliminator and zx6e tail light on KZ650" as the title then the post would be something like this
Then you probably would have started the thread with your initial plans of fabricating your mount.
Some talk about that from others....
Then you researched and decided it would have been easier to use the bracket that comes with the light
Others offer advice about how you could do that.
You then post about how you might be able to adapt the fender eliminator for the 900 and 1000 for your 650
After more research you find those pictures you put in the other thread and post them up here and decide to go for that.
Maybe a few comments about its a clever idea, etc. then the thread is mostly dead unless you think of something else or run into a problem with installing it.
I just don't understand why you make a new thread for every question.
You have 4 threads that could all be put under one.
kzrider.com/kunena/5-chassis/609890-rear...00-and-kz1000#796689
kzrider.com/kunena/4-electrical/609878-l...ht-conversion#796560
kzrider.com/kunena/5-chassis/609864-can-...-light-pics?start=20
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
The following user(s) said Thank You: Scirocco, Warren3200gt
Last edit: by M_a_t_t.
Rear Area Frame Differences between KZ650, KZ900 and KZ1000 13 Jan 2019 10:03 #796689
  • 650Dude
  • User is blocked
Rear Area Frame Differences between KZ650, KZ900 and KZ1000 13 Jan 2019 14:35 #796710
  • stone fruit
  • stone fruit's Avatar
  • Thank you received: 10
The fender eliminator kit from Z1E fits the 650. I fitted one years ago. I also painted it satin black. I didn't use the light mount plate as it was too big for the small LED cat's-eye tail light.
The following user(s) said Thank You: 650Dude
Last edit: by stone fruit.
