Can anyone recommend an AFTERMARKET tail light? *PICS*
- 650Dude
- Banned
Re: Can anyone recommend an AFTERMARKET tail light? *PICS*
19 Jan 2019 14:19Street Fighter LTD wrote: If unaware of proper tool look up a metal brake and just try and imitate it on a crude scale.
Once done with metal work sand and scotch brite metal for final finish and to hide your metal working marks
This part, no one will be able to see, so thankfully I dont have to worry about cleaning it up. See below:
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
- 650Dude
- Banned
19 Jan 2019 14:48Street Fighter LTD wrote: If unaware of proper tool look up a metal brake and just try and imitate it on a crude scale.
As crazy as this may sound, I may actually use a miniature hinge for the part circled in red. Then I wont have to bend anything.
19 Jan 2019 15:02
Rattle , Rattle, Buzzzzzzzzzzzzzzz, Rattle , Rattle , Buzzzzzzzzzzzzzz
Voice of experience. But , Your Bike
Metal is not that hard to bend . Experiment on a extra piece
- 650Dude
- Banned
19 Jan 2019 16:01Street Fighter LTD wrote: Rattle , Rattle, Buzzzzzzzzzzzzzzz, Rattle , Rattle , Buzzzzzzzzzzzzzz
i'll take your advice. dont want rattle and buzz lol
19 Jan 2019 16:46
Trust the expirience metal worker, no hinge or something other stupid things.
Sometimes you have to go or do the difficult way of fabrication for the best result.
I learnd it the same way 40 years ago and it improfed my metal working skills, trust me.
Learning by doing and grow up with every failure, it´s my statemant, i am an autodidact.
20 Jan 2019 15:23
Its always a good idea to rubber mount pieces like this . Your whole bike is done in this fashion
- davido
20 Jan 2019 23:52 - 20 Jan 2019 23:53
My bending jig. easy to build, no special tools needed. Works well. Tail light mount build is towards the bottom of this page somewhere
www.kzrider.com/forum/11-projects/594313...ject-build?start=100
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 20 Jan 2019 23:53 by davido.
- 650Dude
- Banned
21 Jan 2019 06:09Street Fighter LTD wrote: Its always a good idea to rubber mount pieces like this . Your whole bike is done in this fashion
Yep I already thought of that and have rubber bushings etc.
I now have to deal with a wiring issue.
The OEM rear plug for the lights is a 6 pin. The new light has 6 wires since it has two bulbs, 3 and 3 for each bulb. The connector on the new light was made into a 3 pin wire - they put two wires into each pin. Need to figure out how to mate this connector with the OEM.
- Warren3200gt
21 Jan 2019 06:33
You could always look at a wiring diagram, it ain't hard.
- 650Dude
- Banned
21 Jan 2019 06:55 - 21 Jan 2019 06:56Warren3200gt wrote: You could always look at a wiring diagram, it ain't hard.
If anyone else has anything useful to add beyond this obvious observation, I'd appreciate it.
Primarily, Im concerned as to how many wires I can put into each connector slot.
Last edit: 21 Jan 2019 06:56 by 650Dude.
- 650Dude
- Banned
21 Jan 2019 13:04
- rstnick
24 Jan 2019 18:15 - 24 Jan 2019 18:22
As far as the wiring, I can't recall the colors off hand for the ZX6E tail light, but one wire should be black/yellow, which is the ground wire. (Now see that the other wires are red and blue. )
The other two wire colors should be similar to the 650's, or not hard to determine which is the brake light and which is the running light.
Connect the red wires together, the blues, and the black, and attached male plugs to the ends.
I used the wiring from a spare stock tail light to attach to the ZX6E light.
Then it can be plugged into the KZs plugs/wiring.
The red and blue plugs can be swapped around if you find you've connected them wrong to the KZ's harness.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 24 Jan 2019 18:22 by rstnick.
