Help identifying Z tank
  • swirl
  • swirl's Avatar Topic Author
24 Aug 2016 01:19
#739718
As above picked this up a couple of days ago, the frame is kz1000 ltd, anyone know what the tank is thanks Swirl
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Help identifying Z tank
24 Aug 2016 05:41
#739737
need a picture that shows the underside(pinch weld in particular) to positively identify it between kz or z1.
  • Kapahulu
  • Kapahulu's Avatar
24 Aug 2016 13:01
#739771
Whether it's Z1 or KZ1000, more desirable than an LTD tank to many people.
2strokeworld.com
  • GregZ
  • GregZ's Avatar
24 Aug 2016 16:28
#739799
Definitely not a Z1 tank, it has the wrong latch for petrol cap. Its a kz900 or kz1000 depending on the petcock mount. If it has the 22mm threaded type bung you have a good tank. If it has the bolt on petcock you will need a vacuum operated petcock or get a pingel adapter if using non vacuum carbs
this is a Z1 tank front latch mount
  • GregZ
  • GregZ's Avatar
24 Aug 2016 16:30
#739800
If you want to sell the gulliara seat please let me know, been looking for one of those
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2016 16:54
#739803
GregZ wrote: Definitely not a Z1 tank, it has the wrong latch for petrol cap. Its a kz900 or kz1000 depending on the petcock mount. If it has the 22mm threaded type bung you have a good tank. If it has the bolt on petcock you will need a vacuum operated petcock or get a pingel adapter if using non vacuum carbs
My Z1 or KZ 900 tanks don't look like that.
  • GregZ
  • GregZ's Avatar
24 Aug 2016 17:19 - 24 Aug 2016 17:22
#739806
You have a KZ tank as well.
Z1 tank has a latch, no key
KZ tank has key
Last edit: 24 Aug 2016 17:22 by GregZ.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2016 17:35
#739807
One came off a KZ the other is a Z1b tank.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2016 18:02
#739812
Seems I have a mystery on my hands. I had a latch years ago and went to a key type. After looking at the Z1 tanks both of mine don't have the cutouts on the bottom. Greg, I stand corrected. I had the Z1 tank on the bike in the wreck and a wrecked KZ 900 for parts. Question is where did I get two late model tanks? THAT's gonna bug me. :angry:
  • floivanus
  • floivanus's Avatar
24 Aug 2016 18:54
#739821
I couldn't tell from the blurry pictures, but greg nails it like usual.
The bolt on petcock style tanks I usually use some 1/4" thick aluminum and a 3/8 npt tap to make my own adapter, but there actually are some $30 or so manual petcocks that fit those tanks. I can't vouch for their quality (it's sitting on my parts shelf in my shed, behind my H2) but it's an option
Past; 78 kz1000, 83 kz550
Andrew
  • swirl
25 Aug 2016 01:06
#739856
GregZ wrote: If you want to sell the gulliara seat please let me know, been looking for one of those
Hi GregZ the seat is for sale, I have someone interested but he hasn't made a firm offer yet, where are you located.
I'll grab some more pics of the tank when I go my lockup
  • swirl
25 Aug 2016 04:04
#739858
More pictures
