Tire fitment issue
  • Olajoe
  • Olajoe's Avatar
  • Free at last
Re: Tire fitment issue
28 Mar 2016 19:35
#717881
somebody said something might have happened to those rims that we didn't know about preventing it from seeding ;)
well you guys talk me out of it no tire changing rigs for me. I want to be that guy that gets the deal from the pro too. if this event happened at my shop I would lose sleep over it those are nice irons the nomars.
  • RonKZ650
  • RonKZ650's Avatar
28 Mar 2016 20:27
#717898
Could be a defective tire, but extremely rare if that is it. I don’t think the KZ550 has tubeless setup, mounting a tire and have it seat correctly on a tube type wheel should never be any problem. Getting them to pop out and seat on a tubeless wheel can be slightly more involved, but still fairly straight forward. I've changed my own tires since 1975 and never had a defective tire yet or much problem in seating. Over the years a few times had areas that didn't want to seat, so released air and relubed the problem area, and try again.
One problem with tubes is it is possible to have the tube not 100% in the carcass of the tire, particularly at the valve stem. Sometimes the tube due to the extra rubber ect around the valve stem area can be pinched in between the tire and wheel. If they don't do many tube type wheels, this would be a possibility and my guess as to the problem.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Mar 2016 20:40
#717900
With so many working on it would seem to me the tire is not compatible.
  • carwash
  • carwash's Avatar Topic Author
29 Mar 2016 04:13
#717930
They're tubeless tires.
RonKZ650 wrote: Could be a defective tire, but extremely rare if that is it. I don’t think the KZ550 has tubeless setup, mounting a tire and have it seat correctly on a tube type wheel should never be any problem. Getting them to pop out and seat on a tubeless wheel can be slightly more involved, but still fairly straight forward. I've changed my own tires since 1975 and never had a defective tire yet or much problem in seating. Over the years a few times had areas that didn't want to seat, so released air and relubed the problem area, and try again.
1980 KZ550A
1980 CB750F
29 Mar 2016 04:50 - 29 Mar 2016 04:52
#717934
carwash wrote: They're tubeless tires.
It doesn't matter that they are tubeless tires; they still MUST have tubes in them for them to work on the 1980 KZ550-A1 wheels. A tubeless tire does NOT make the wheel a tubeless type wheel. If your shop did not put new tubes in them (as I pointed out in my first reply) go to another shop because they have no clue as to what they are doing, and they may land you in the hospital. Keep in mind that you will be the one riding the bike, not the guy mounting the tire. Seriously, check to see if they installed new tubes. If not go get your wheel and tire back from them and take it to a competent shop. Ed
Last edit: 29 Mar 2016 04:52 by 650ed.
  • carwash
29 Mar 2016 05:00
#717936
Yep, I supplied them with new tubes. They got the rear tire to set, no problem. Looking deeper into this, the rims aren't stamped "tubeless", so i assume they are tube-only set up. However, the tires I got are tubeless tires which I was going to run with tubes. I was under the impression this was ok to do. Maybe it's not and is what's causing the problem. I'll be speaking with the retailer today, where I got the tires. I may end up pulling both off and going with another, tube-type model.
1980 KZ550A
1980 CB750F
29 Mar 2016 05:08
#717938
Running tubeless tire with tubes in them is perfectly normal. It will not cause any problem. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Mar 2016 07:18
#717961
I would like to see the markings on the tire and rim.
  • carwash
29 Mar 2016 09:36
#717985
what markings?
swest wrote: I would like to see the markings on the tire and rim.
1980 KZ550A
1980 CB750F
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Mar 2016 11:54
#718024
The ones on the sidewall of the tire and the markings on the rim.
  • JR
  • JR's Avatar
29 Mar 2016 14:01 - 29 Mar 2016 14:32
#718043
Does it say TUBELESS on the spoke or rim ?
Look for something like this below
This is my rear wheel. Front is the same.
I dont have any experience with a 550 but others have posted that tubes should be used on the 550 unless a PO has made changes
EDIT Just noticed carwash's post from 9 hours ago so disregard mine above
Last edit: 29 Mar 2016 14:32 by JR.
  • Nessism
  • Nessism's Avatar
  • Away
29 Mar 2016 14:24
#718046
If the powder coat guy really laid on the coating thickness that could be keeping the bead from seating. Powder coat is quite thick.
What kind of lubrication was used on the tire and wheel? Real tire lube or soap?
