Z1R rear shock disassembly question
- PaintWorkz
22 Dec 2015 15:47
Does anyone have any experience removing the springs from the shocks on a 78 or 80 KZ1000 Z1R? I see the roll pin under the top eye and flats on upper casting.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
Re: Z1R rear shock disassembly question
22 Dec 2015 16:04
It might be possible to use a spring compressor like the ones for struts. My new shocks have a slot in the top retainer. They'll be easy. The ones I took off have a pin but it is buried in the casting. I've been thinking of switching the covers so my new ones will have the reflectors. I rented a compressor from Auto Zone when I installed strut cartridges in a Maxima three years ago. It looked like it would work on smaller springs.
23 Dec 2015 03:45
i've seen what you are talking about paintworkz.
it stands to reason you would drive out the pin and be ably to screw the eye off.
but i have never done it myself,and therefore don't know for sure.
let us know what you do.
23 Dec 2015 04:20
Progressive makes a spring compressor for their shocks that might work on yours.
23 Dec 2015 04:24
I am not sure what the difference between the two models is, but I'm sure they'd be happy to 'splain it.
www.progressivesuspension.com/product/14...-tool-for-psi-shocks
- PaintWorkz
23 Dec 2015 04:54
I ordered a spring compressor set up, I understand that would be the first step for disassembly. I am not sure on the rest of the steps. I don't want to wreck stuff knocking the roll pin out or trying to do something else that is not right.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
84 Gpz900 street
77 1135 KZ900 A5
23 Dec 2015 05:05
Rent was the wrong word. I had to buy a compressor, use it then return it and got my money back. AZ offers the same service. Only one style was available and I had to be careful I didn't get a damaged one. They had two. One was damaged so I insisted on the new one otherwise I would have had to keep the damaged one. Nice try.
www.oreillyauto.com/site/c/detail/SPP0/4...p?pt=N2403&ppt=C2370
23 Dec 2015 05:11
I wonder if a couple of days soaking in PB Blaster would make pin removal go more smoothly?
23 Dec 2015 05:17
It may help but if it's a roll pin and it's at the top of the shock, it should drive right out with the proper size punch.
23 Dec 2015 05:34
23 Dec 2015 05:44
Just be careful that thing doesn't go spriongggg. :whistle:
- mrdatsunturbo
- mrturbo Norway
23 Dec 2015 08:40
It is one week since i had one of my z1r shocks apart.
Spring compressed. knock pin out and turn the upper eye on the square nut under top eye.
Attachment 2015-05-2818.02.31.jpg not found
