disassemble rear shocks?
  • worm556
  • worm556's Avatar Topic Author
22 Mar 2009 23:04
#274439
How do I get these apart so I can sand and paint them? I removed the roll pin at the top but can't get them to separate. They are from a 81 kz 440 but going on my 83 kz550.
1983 KZ550 Spectre "Combat KZ"
  • worm556
Re: disassemble rear shocks?
25 Mar 2009 23:02
#275467
I figured it out.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
26 Mar 2009 02:38
#275474
So, how exactly did you take the shocks apart?:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • worm556
26 Mar 2009 20:20
#275695
Had to remove the roll pin, compress the spring about an inch to get to the slotted part on top of the piston, then un screw the cap.
Here it is all cleaned up ready for paint.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
27 Mar 2009 09:50
#275808
way to perservere!
thanks for sharing.
leon holmes
  • kztee
  • kztee's Avatar
  • TeeRoy
30 Mar 2009 17:03
#276854
I'm trying to fit some Suzuki shocks but the top mount is a differnt size. Plus I would like to paint them too. What did you use to compress the spring? I'm trying to modify a car type spring compressor.
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
  • worm556
01 Apr 2009 01:06
#277291
I just pulled the spring down by hand, wedged a screwdriver in between the cap and the spring, then shoved a small socket in there. Then I just kept cramming in larger sockets untill I could squeeze a wrench in.
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
01 Apr 2009 05:12
#277311
I have used huge zip tyes I got at Lowes, the strongest I could find, to do a dirt bike rear monoshock. One on each side.
To put it back together, I used 2 big washers, 2 nuts and a piece of threaded rod.
Crank the nuts down to compress the spring, zip tye it compressed, then slowly loosen the nuts again.
Put the spring on the shock, put it together, and cut the zip tyes.
That's probably what I would try here too...I think it would work. You don't need to compress it all that much to get them back together anyway. If the springs seem too stiff, then don't do it.
Just don't point the springs at anything you want to keep.:laugh:
Build Thread
  • worm556
28 Apr 2009 21:53
#286127
Painted and reassembled, used the zip tie technique.
  • kaw74z1
  • kaw74z1's Avatar
  • 0 to 60 in 15 minutes.
28 Apr 2009 22:12
#286131
Some good info.;) And they sure do look good. :)
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
  • TexasKZ
  • TexasKZ's Avatar
30 Apr 2009 13:53
#286551
Nice job, though for $35 one of these is mighty handy.
street.parts-unlimited.com/21/173/7867353
  • TexasKZ
  • TexasKZ's Avatar
30 Apr 2009 13:56
#286553
