Swing arm mod Z1/ZZR1200
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Swing arm mod Z1/ZZR1200
10 Dec 2015 13:07
#702647
There's still one on my watch list. $145 That money can be spent on other things right now.
  • SWest
  • 10 22 2014
15 Dec 2015 14:42 - 15 Dec 2015 15:10
#703231
Well no one spoke up about wanting it so I decided to hack it up. I talked to my welder/machinist and he said he would do it if I had all the pieces cut and ready to go. I'll pop rivet a couple plates on while I'm fitting it.
I know, a carpenter thinks everything is a nail. :lol:
I'll have to relieve a few areas to miss the brake arm and parts of the frame. Got some good hard aluminum sheet for that. Also have some 13,69mm plate for the brake stay and shock mounts. I'll be getting a new rear tire after Xmas and that's when I'll get the final measurements. I figure what the hell, I'll ether have a beefier swing arm or $23 in scrap aluminum. :whistle:
Last edit: 15 Dec 2015 15:10 by SWest.
  • ajsfirehawk
  • ajsfirehawk's Avatar
15 Dec 2015 15:19
#703234
Keep raging against the machine Steve. Considering doing this on an 82 GPz 750 project that is coming next summer. I'm watching with baited breath. :woohoo:
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
Z900RS
23 Mach 1
  • SWest
  • 10 22 2014
15 Dec 2015 15:37
#703237
With all the fantastic mods here, I felt left out. The Z1's were known for their high speed wobble. :ohmy: I've been in them and scary is not the word. :dry: All I could do was to give it a little more throttle, squeeze the tank with my knees and ride through it. I had one in Tehachapi last year, almost went down. Hopefully this will solve the problem along with some frame gusseting. :whistle:
  • rrsmsw9999
  • rrsmsw9999's Avatar
15 Dec 2015 19:03
#703249
That looks good. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • scubaanders
  • scubaanders's Avatar
Re: Re:Swing arm mod Z1/ZZR1200
15 Dec 2015 19:22
#703253
Sweet Steve.
I have never seen it done that way. Looking forward to whats next, are you going with Leons mushroom bushings?
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • SWest
  • 10 22 2014
16 Dec 2015 03:47 - 16 Dec 2015 03:49
#703256
That's the plan. I should have checked the square of the blade on my 30 year old Skil saw. After I made the first cut I was committed and had to make the other cuts in the same direction. They mate well but look like SHT. :unsure: Welded and gusseted, they won't be seen. :whistle: "Can't see it from my house." :lol:
The trick will be making it fit inside the frame and miss the brake control arm. It would have been easier if I had the one that was burned in the fire for a template. At that time, the whole area was being hit by scrap thieves. :angry: Anything metal was taken including a spare A/C unit I had in my front yard. I caught three of them scoping out my neighbors place. Illegal aliens. Oh, (undocumented workers) :dry: and when they saw me with my 44 hog leg strapped to my hip, they scurried away like rats. :woohoo:
I'll fit it as I had planed in the beginning, maybe cutting and making my own bushings and shims, then send them to Leon to match. I need to get another stock pivot shaft to work with. The ZZR shaft can be cut and washers brazed to it for mock ups. We'll see.
Last edit: 16 Dec 2015 03:49 by SWest.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
16 Dec 2015 03:54
#703257
way to "go for it"steve :woohoo: !
i got a chuckle out of it.
i clicked into this thread and was like damn he did cut it in half :evil: !!!
i'll help any way i can.
are you keeping it the same length?
  • SWest
  • 10 22 2014
16 Dec 2015 04:04
#703259
It's about 1" longer. That should help too and not look bad. I love the way it handles stock and 1" longer should make it a little more stable at high speed.
  • 531blackbanshee
  • Vendor
16 Dec 2015 04:13
#703260
sweet ,
yeah that will be fine.
  • SWest
  • 10 22 2014
16 Dec 2015 06:17
#703263
I thought I'd put this clip in the thread to tie it all together.
  • SWest
  • 10 22 2014
16 Dec 2015 13:54
#703296
Added a couple temp gussets so I can size it up. Looks like I'll have a lot more cutting to do. :dry:
