Alloy wheel repair?
  • Tyrell Corp
  • Tyrell Corp's Avatar Topic Author
Re: Re:Alloy wheel repair?
22 Oct 2015 05:45
#695461
Looks like the rim has already been repaired? quite localised damage around the outside of the rim - to the eye.
What is there to lose? The uncertain risk of life endangering catastrophic failure and quite a sought after bike. I had a brake caliper mount fall apart from metal fatigue or casting imperfections years ago, these bits are highly stressed with a finite design life, which a lot of us are exceeding now.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Oct 2015 05:53
#695463
Go by your gut, it is seldom wrong.
The following user(s) said Thank You: Tyrell Corp
  • scubaanders
  • scubaanders's Avatar
22 Oct 2015 06:39
#695469
Tyrell if it has a structural damage it's a total loss. Like cracks around the hub or on a spoke. But if it's only on the lip?
Back here we have shops that does that kind of repair and I have a feeling that I have seen the guy's on Wheeler dealers geting vintage car rims fixed in the UK.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • pete greek1
  • pete greek1's Avatar
22 Oct 2015 07:35
#695481
IMO, I wouldn't take a chance with repairing it, It's not the same as having a car rim fail, as you still have 3 other wheels on the ground & you're in the car surrounded by 2000 lbs. of metal,...not as life threatening as a failed rim on a motorbike
Pete
The following user(s) said Thank You: PLUMMEN, Tyrell Corp
  • Tyrell Corp
22 Oct 2015 09:58
#695500
A bit more googling, a finite element analysis of a spoked alloy car wheel is showing top numbers of 160 MPa pressures, or 23 000 lbs/inch, 1.6 tonnes /cm2 . Then put a few billion cycles, bumps and wheelies and the fatigue stresses get really high.
I read in an 80's UK bike mag that the z650 models had some alloy wheel failures, but never heard this anywhere else.
  • loudhvx
  • loudhvx's Avatar
22 Oct 2015 11:01 - 22 Oct 2015 11:04
#695504
A good welder could to repair that to like-new. I had a bad crack in an alloy car wheel. The welder where I worked welded it up and somehow even matched the color of the alloy. After I was done grinding/sanding/polishing it, it was almost impossible to find the repaired area.
Make sure to hog out all of that J-B weld.
Last edit: 22 Oct 2015 11:04 by loudhvx.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
22 Oct 2015 11:06
#695506
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • redhawk4
  • redhawk4's Avatar
22 Oct 2015 19:02 - 22 Oct 2015 19:24
#695560
I'd personally find that damage very distracting and unnerving I'd be checking my wheel every time I hit a bump, but it must be repairable if you find the right person, there are even companies who can widen an alloy rim for you, so in comparison this would be a doddle.
I assume this is the rare 18" front rim? is it much different from the 18" Police front rim. It seems to me the Police rear 18"x 2.5" rim I just got t o pt on my KZ1000 is pretty much identical to the rim of my 1981 K1000J I had in the UK in 1982, which was pretty much a 1000R other than cosmetics - although I could be being misled by the intervening 33 years :(
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 22 Oct 2015 19:24 by redhawk4.
