Alloy wheel repair?
  • Tyrell Corp
  • Tyrell Corp's Avatar Topic Author
Alloy wheel repair?
21 Oct 2015 11:32
#695329
How bad is this? it runs true.
  • floivanus
  • floivanus's Avatar
Re: Alloy wheel repair?
21 Oct 2015 11:37
#695331
Bad enough I'd replace, but it could be welded... Maybe
Past; 78 kz1000, 83 kz550
Andrew
The following user(s) said Thank You: Tyrell Corp
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
21 Oct 2015 11:41
#695333
Tyrell Corp wrote: How bad is this? it runs true.
I personally would not want to run that wheel at speeds. Shows signs of deep fractures on a CAST wheel
If steel or forged I would give fixing it a try.
Could only imagine going deep into a fast corner and having it fail
Dave B) B) B)
  • Tyrell Corp
21 Oct 2015 11:47
#695334
Apparently the bike it is fitted to has passed a uk roadworthiness test with the wheel like that.
I've scrapped a few of these over the years,just this one is a bit special...
  • Nessism
  • Nessism's Avatar
21 Oct 2015 11:47
#695335
I tend to doubt it would cause issues. Those old cast wheels have a LOT of metal in them. The damage it out on the lip of the rim too.
You can pick up new/used wheels for very affordable prices. I'd look for a new wheel and swap it out next tire change.
  • PLUMMEN
  • PLUMMEN's Avatar
21 Oct 2015 13:43
#695356
As cheap/common as factory wheels are Id chuck it unless its something odd like a Z!R rim. ;)
  • Tyrell Corp
21 Oct 2015 15:32
#695378
it is an 1100R 18 inch 7 spoke, super rare. This damage uncertainty is probably a deal breaker.
  • Nebr_Rex
  • Nebr_Rex's Avatar
21 Oct 2015 15:51
#695382
Wheel is repairable. All depends on how much you trust the guy welding it.
If it was me I'd run it but, I'd be the one welding it.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • floivanus
21 Oct 2015 16:08
#695389
Weld it and run it, find a good welder and ask, worst case you're left with a bit of porosity and a tube after welding
Afterall, when are you even going to find 1100R parts?
Andrew
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Oct 2015 16:57
#695399
My Lester front mag was losing air. The rear was destroyed in the wreck. I didn't trust it so I got rid of it. BIG mistake. I'd have it fixed and run a tube.
  • Tyrell Corp
22 Oct 2015 05:23
#695458
Googling this further it seems opinions are really split on repairing cast alloy wheels, even the welding forum has some sharply contrasting opinions.
The other issue is testing it, as a minimum dye testing but preferably x ray. Unless I did that I'd never fully trust it. I think I'll pass on it.
  • scubaanders
  • scubaanders's Avatar
Re: Re:Alloy wheel repair?
22 Oct 2015 05:35
#695460
If the rim i strait when measured and it's only the lip that is damaged, I would definatly leave it to a welder that has experience with car rims and try to get it fixed. What is there to lose?
We have welded boat props and they have worked like new, why not a sturdy bike rim.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
