Lower fork tube polishing
- Rockranch
21 Sep 2015 01:00
I'm looking for different methods of polishing off the dull stock factory finish of the lower front fork tubes. I know they can have a highly polished appearance when they are done, and look quite awesome. But I can't seem to find the right method. I've heard there's an easy way to get the look I am seeing in others.
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
1 modified
Re: Lower fork tube polishing
21 Sep 2015 02:54
If they have a factory clear coat, here's a topic in which acetone was used.
Cleaning those Ugly Yellowed fork tubes
The following user(s) said Thank You: Rockranch
- Rockranch
21 Sep 2015 03:14
Thank you Martin. That's the first I've heard of using acetone. It certainly sounds like a logical and practical method to accomplish what I'm looking for. I will give it a try.............Mike
1 modified
1 modified
21 Sep 2015 03:22
The 70s models may not have the clear coat --- not sure what bike you have.
- Rockranch
21 Sep 2015 03:25
I have 3 '76 KZ900's and a '77 KZ1000
1 modified
1 modified
21 Sep 2015 03:35 - 21 Sep 2015 03:36
I don't really know, but yours may not have the coating & might be just oxidized instead. ???
My 81 650 had the clear coat ---- I wish I'd seen that acetone topic before doing mine the hard way. doh.
Last edit: 21 Sep 2015 03:36 by martin_csr.
- z1kzonly
21 Sep 2015 04:57Lower legs have lacquer finish on them. Buy a cheap aerosol can of paint, gasket stripper.Rockranch wrote: I have 3 '76 KZ900's and a '77 KZ1000
And you need to buff with a bench style electric motor buffer at least 3450 rpm's.
I always glass bead my aluminum, then some fine scotch wheels then wet sand with auto paint wet sand paper 400-600 grit.
Good thing you can do forks assembled if your internals are good. Easy to hold, aluminum gets hot!
The machine buffing with the correct compound does it.
Here's a couple of front ends I've sold on ebay over the last few years.
Good luck! Patience and your own labor and sweat equity are free! If you have the time.
- missionkz
21 Sep 2015 06:51
My '77 KZ1000 has lacquered, urethaned or plastic coated lowers.... after 42,000 miles on the road they are starting to pit on the front and I can polish the aluminum under the coating.... that looks weird now so that will be a winter project for me too.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- RODZ
21 Sep 2015 09:46
After polished , take over paint ? trasparent obvious ...
- missionkz
21 Sep 2015 10:00
I tried the acetone with rags.... it doesn't hardly cut this stuff at all... this will be a lot of work with acetone and it can make me dizzy followed by puking.
Bruce
1977 KZ1000A1
1977 KZ1000A1
21 Sep 2015 10:48 - 21 Sep 2015 10:48
My method to polish aluminum (engine cases, fork lowers, etc)
1) Paint stripper to remove the clearcoat (KZ fork legs)
2) DA sander w/220 grit
3) Buffer w/sisal wheel and black cutting compound
If you want a "brushed" finish like OEM, then take some 800 grit sandpaper or gray scotchbrite pad and apply uniform strokes in the desired direction. If you don't want the brushed look then I finish with some Mother's polish applied by hand to remove swirls.
Optional: use clear coat so seal the aluminum. Por-15 Glisten clear works well.
I recently finished these engine covers (sans clear coat). The fork legs were cleared though.
Last edit: 21 Sep 2015 10:48 by Nessism.
The following user(s) said Thank You: PLUMMEN
22 Sep 2015 03:33
How disgusting --- that my parts don't look that good. (Insert homer simpson drool pic here).
