kz400 rotor options
Re: kz400 rotor options
03 Sep 2015 16:29
Yup, almost went with them. They wouldn't slim down the disks tho, so the stock light weight ones were the obvious choice. 1/2 the weight of the solid ones. I could feel those heavy disks bouncing up and down. Now smooth as glass.
- captain awesome
03 Sep 2015 17:32
I may have just found a set of forks/trees/front wheel/disc/caliper/bars etc. from an h1 triple locally. Pretty sure they have 36mm forks and should bolt right on for only $100. Seems like a pretty good deal and then I can get that rotor drilled to reduce weight. I've seen there is a commonly upgraded caliper that's fairly light weight as well.
03 Sep 2015 18:36
What's the bolt pattern on the H1? Pics?
- captain awesome
03 Sep 2015 18:57
fayar.craigslist.org/mpo/5185701170.html
This is the ad. I don't know what the dimensions are but I know the fork size is a 3mm jump from the stock kz400 33mm forks.
03 Sep 2015 19:24 - 03 Sep 2015 19:24
That thing could be worth some money if put back together. You'd have to use the whole thing.
Last edit: 03 Sep 2015 19:24 by SWest.
- captain awesome
03 Sep 2015 19:36
The thought has crossed my mind but it's already taken apart. I don't know if it's something I really want to mess with right now.
03 Sep 2015 19:44
Can you take a look?
- captain awesome
- captain awesome
04 Sep 2015 07:01
Apparently there is someone already planning to pick the whole project up this afternoon, but if he bails I'm next on the list. Oh well, I've been staring at the ad for a couple weeks now, surprised it didn't sell way quicker.
04 Sep 2015 07:14
I know someone that has a complete H1. His wife is as big as a house, he has a ring in his nose but he won't sell it. Whenever I ride by, I have his undivided attention. She glares at me. :ohmy:
I just don't understand. :dry:
- captain awesome
04 Sep 2015 12:32
Took some measurements last night, but forgot to post them.
Stock kz400 disc
77mm bolt pattern
57.67mm ID bore
11 7/8" OD of the disc
~10mm offset
Stock kz400 disc
77mm bolt pattern
57.67mm ID bore
~10mm offset
