Help! Oil coming out of the fork air valve
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
08 Aug 2015 14:33 - 08 Aug 2015 14:34
#684953
I am taking the fork leg out of my 82 GPz750 and the fork oil was coming out of the air valve when I removed it. I am doing this to change the fork oil seals because there is oil coming down the outer tube on the right. There was also no air pressure when I removed the valve. What is my issue besides my fork seals if any?
Last edit: 08 Aug 2015 14:34 by GPzMOD750.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Help! Oil coming out of the fork air valve
08 Aug 2015 14:40 - 08 Aug 2015 14:41
#684957
Dude, you got to take care of that hand. :lol: :woohoo:
You can buy new Schroeder valves at AZ or OR.
Last edit: 08 Aug 2015 14:41 by SWest.
  • GPzMOD750
08 Aug 2015 14:42
#684959
Self healing. Bike ain't.
  • GPzMOD750
08 Aug 2015 14:44 - 08 Aug 2015 14:45
#684960
IDK if there is an issue with the air valve or if there is a seal or valve issue inside the fork.
Last edit: 08 Aug 2015 14:45 by GPzMOD750.
08 Aug 2015 14:45
#684961
How much air pressure have you been running in the forks? Ed
  • GPzMOD750
08 Aug 2015 14:46
#684962
650ed wrote: How much air pressure have you been running in the forks? Ed
this bike is new to me. first I've done anything with the forks.
  • Tyrell Corp
  • Tyrell Corp's Avatar
08 Aug 2015 14:49
#684965
If oil is leaking out when you remove the valve it might be the oil level is too high, IIRC there is a misprint in the manuals but I used 250ml either side, blended 12 weight but I'll go 15 or more next time. I remember taping up the oil holes when filling the loose forks.
Add some air, maybe 10 psi with a hand pump and see if it holds it. Too high pressure with an airline will pop your seals.
The following user(s) said Thank You: GPzMOD750
  • GPzMOD750
08 Aug 2015 14:54
#684968
Tyrell Corp wrote: If oil is leaking out when you remove the valve it might be the oil level is too high, IIRC there is a misprint in the manuals but I used 250ml either side, blended 12 weight but I'll go 15 or more next time. I remember taping up the oil holes when filling the loose forks.
FSM says 256+/-4 if filling dry.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Aug 2015 14:57
#684971
I put some on mine years ago. Leaky seals. Progressive springs, new seals AGAIN, put hard caps on the valves and no more problems.
  • GPzMOD750
08 Aug 2015 15:04 - 08 Aug 2015 15:04
#684974
OK from what I can tell, It isn't necessarily a bad thing for oil to come out of the air vale and the recommended pressure is 10 psi +/- 3 or so,
Last edit: 08 Aug 2015 15:04 by GPzMOD750.
