MC Enterprises case guards
- 9er rider
- Keep a cool tool
Re: MC Enterprises case guards
22 Jun 2015 09:40
Great idea but I dont want to drill holes in my stock frame. Im still intrigued though. If anyone actually builds a set send a pic that shows details
- RFE81LTD1K
22 Jun 2015 10:13Me either. I've come up with another design that won't involve drilling holes in the frame.9er rider wrote: Great idea but I dont want to drill holes in my stock frame. Im still intrigued though. If anyone actually builds a set send a pic that shows details
It would use the front engine mount and the mounting tab located on the frame under the engine side cases. A flat pc of plate could be cut that follows the frame between those two points. Basically in a "C" shape. The pegs could then be mounted to the plate/bracket anywhere you felt was comfortable. I think 1/4 steel plate about 1 1/4 inches wide would do fine. Wider the better. I only said 1 1/4 because that's how wide those tabs on the frame are.
81 KZ1000 LTD
All original.
15k miles.
All original.
15k miles.
22 Jun 2015 10:52
Look at the clamps on my pegs. You might get some ideas.
- RFE81LTD1K
22 Jun 2015 12:48 - 22 Jun 2015 12:50Yes, I thought about using clamps like that around the frame below the front engine mounts. And they would probably work fine using standard length pegs. Ad a 4-5 inch extension to that peg and now that clamp would have to stay in place with 8-9 inches of leverage on it. I'm not sure you could get it tight enough to not slip around on the frame. Maybe if the clamp was one of those with two bolts going through it / it would hold better. ???swest wrote: Look at the clamps on my pegs. You might get some ideas.
81 KZ1000 LTD
All original.
15k miles.
All original.
15k miles.
Last edit: 22 Jun 2015 12:50 by RFE81LTD1K.
22 Jun 2015 12:52
They have two pinch rings that dig into the bar or frame. I'll get pics later today.
