Tire stuff Shinko
  • OLKZ
  • OLKZ's Avatar
Re: Tire stuff Shinko
27 Jul 2015 10:16
#682980
Ok, great, 100/90-19. These shinko tires seem really reasonable. Any reason to look for anything better? The comments here have been pretty positive.
Thanks for the help.
1978 KZ650B2 - Blue - runs!
New Dyna-S ignition & coils 6-2014
  • jackleberry
  • jackleberry's Avatar
27 Jul 2015 10:20
#682982
I've been running the Shinko F230 and 712s for about 6 years now. I like them. They handle better than the Dunlop tires I've had.
Because of size and rating and price I run an F230 front and a 712 rear. I live in the PNW where it the roads are wet constantly, and they perform well. I found the longevity of the F230 rear to be the same as the 712, so I go with the cheaper one there.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • missionkz
  • missionkz's Avatar Topic Author
27 Jul 2015 10:24 - 27 Jul 2015 10:26
#682983
I have about 475 miles on the 712s now and so far, so good!
75mph-85mph at freeway speeds... smooth.
Had the bike up to +120mph on the speedo a couple times... nothing notable, other then normal KZ1000 handling stuff.
I've ridden in rain .... no problem... spirited riding on super hard core 25mph to 50mph switchback mountain roads... no problem... 10-12 miles of well maintained dirt roads... not bad at all.... two up riding... all good.
No wobbles or head shake... all in all... a pretty good pair of tires for under $120.00 plus shipping was free.
Equal to a pair of high end big name tire brands? Well, I doubt it but I am quite happy with these, especially compared to the old, and well used rear Metzler and front Avon that was on it.
Also, there was no problem with balancing, as some others have suggested/claimed, although my rear Shinko 712 (120/90 H-18) needed a full 2 ounces to get balanced.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 27 Jul 2015 10:26 by missionkz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2015 10:27
#682985
Third rear tire for me. About 4-5000 miles to a tire. I'm on a 1000, it should last longer on yours.
  • missionkz
27 Jul 2015 10:30
#682986
Steve. Any problem with the 130 pushing into the chain guard?
Bruce
1977 KZ1000A1
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2015 10:33
#682987
No I ditched that long ago. I made my own.
  • OLKZ
  • OLKZ's Avatar
27 Jul 2015 11:31
#682996
An online dealer would be the only option, since I couldn't find such a tire locally. Whom do you suggest? Any problems with motorcycle superstore.com? Does Z1 sell tires? I should check.
  • jackleberry
27 Jul 2015 12:17
#683003
OLKZ wrote: An online dealer would be the only option, since I couldn't find such a tire locally. Whom do you suggest? Any problems with motorcycle superstore.com? Does Z1 sell tires? I should check.
I buy them from motorcycle superstore. They usually ship faster than anyone else and have the best price. Buy a pair and you get free shipping, but the shipping is only like $6.99 for one tire, which is less than Z1E will charge you to ship a single o-ring.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • missionkz
27 Jul 2015 12:25
#683005
That is where I bought mine earlier this spring.
Shipping is free for two tires from Motorcycle Superstore.
www.motorcycle-superstore.com/search/go#w=shinko%20712
120/90H-18 is $56.00
100/90H-19 is $49.00
if it will fi the fender and bracket bolts (etc)...
the 110/90H-19 is $54.00
Pretty solid deal for a pair of tires.
Bruce
1977 KZ1000A1
27 Jul 2015 15:19
#683034
Also check out denniskirk.com Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Jul 2015 06:51 - 28 Jul 2015 06:51
#683101
I think I'll go back to the 120/90-18. I just noticed my tire track is very narrow on my dirt driveway. That being the case the tire is wearing in the middle too fast.
Last edit: 28 Jul 2015 06:51 by SWest.
  • Nessism
  • Nessism's Avatar
28 Jul 2015 07:06
#683103
Not sure how wide the wheel is on some of you guys's bikes but a 120 is a bit big on a 2.15 wheel but doable. I wouldn't run a 130 on a 2.15.
I've run the 230 Shinko before and thought it was a decent tire. It took more balance weight than some other tires I've used but it wasn't too bad. Longevity is nothing to write home about, but from what I've read the handling is good right to the end.
