question for fitting new ZRX shocks to the KZ
  • richrand
  • richrand's Avatar Topic Author
04 Apr 2015 12:59
#666517
I picked up a pair of ZRX shocks and went to install them today. I got the rightside on just fine, but the left side is touching the chain. I'm not happy about not running without the chain guard, but I can live with it. What's the best way to solve this problem? Do I maybe move the bottom left shock mount out about .5''? If I do that, do I have to do anything with the top mount? Thanks.
Attachment 2015-04-0414.55.41HDR.jpg not found
  • 78kzturbo
  • 78kzturbo's Avatar
Re: question for fitting new ZRX shocks to the KZ
04 Apr 2015 13:17
#666519
i would recomend notching out your chain gard or modifying it. you could also build you a custom chain gard. i would not recommend modifying the frame shock mount or changing the geometry of the bike. by the way nice looking shocks. dave
The following user(s) said Thank You: richrand
  • richrand
04 Apr 2015 13:34
#666522
I would totally do that, but the shock coil is actually touching the chain. Not ridable as is. Maybe I'm just f'ed with these shocks?
  • DoctoRot
  • DoctoRot's Avatar
04 Apr 2015 14:56
#666531
Most people i have seen run these also do a ZRX swing-arm swap and they move the upper mount out as well. are the shocks handed? if so, try switching them side to side.
  • 78kzturbo
04 Apr 2015 15:56
#666545
Im sorry i misread the question the first time. I will give this some thought and get back to you. :dry:
  • floivanus
  • floivanus's Avatar
04 Apr 2015 16:53 - 04 Apr 2015 16:55
#666557
How much is it touching? If you arent too far up the spring maybe a 530 conversion and smaller sprockets would help? Ehh looking at it I kind of doubt it though
Take a pic so we can gawk
Past; 78 kz1000, 83 kz550
Andrew
Last edit: 04 Apr 2015 16:55 by floivanus.
  • 78kzturbo
04 Apr 2015 17:07
#666560
I was thinking that the 81-82 gpz 1100 swingarms might be a little wider at the rear. If so that may give you enough clearance. that may be an option and i know the inside pivot area is the same. im assuming your keeping the stock look. Or maybe as floivanas said chain conversion.
  • DoctoRot
  • DoctoRot's Avatar
04 Apr 2015 19:18
#666586
530 chain is the same inside width as a 630, but they can be a tiny bit thinner depending on the brand. The other option might be to go up a tooth or two on your front sprocket to use a smaller rear sprocket which might give you some more clearance.
  • NakedFun
  • NakedFun's Avatar
04 Apr 2015 19:54
#666590
What about flipping the shocks upside down? I believe the upper mount/body is considerable narrower than the spring section. Might give you enough.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • davido
  • davido's Avatar
05 Apr 2015 00:41
#666605
GS1100 swingarm with new shock mounts welded on??
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
The following user(s) said Thank You: Randombeat
  • etbike3135
  • etbike3135's Avatar
05 Apr 2015 14:07
#666647
I think its the wheel and sprocket carrier. If it was a ltd wheel or z1 I think it would fit.
1973 Kawasaki Z1
18 years in dragbikes
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Apr 2015 16:08
#666659
I've read here that to off set the wheel doesn't cause problems on the radical builds. How about off setting it 1/4"?
