Monoshock Mount Material Thickness
  • diego092409
  • diego092409's Avatar Topic Author
19 Sep 2014 05:02
#648033
Getting ready to design the upper mount for my monoshock on my 82 GPZ1100. The Fuel pump and stator are right behind this location so I would like to be able to bolt the horizontal member onto some tabs welded into the frame to allow for removal. What thickness material should I be looking at for vertical tabs and the cross member. I have some 1/4" thick angle but I am wondering if that is too heavy? What kind of forces is the cross member going to see? Your input is appreciated.
1982 KZ1100 B2 - 'Old Red' kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Monoshock Mount Material Thickness
19 Sep 2014 06:26
#648045
turboguzzis picture shows us how kawasaki did it and they used 1/8 walled plumbers pipe :sick:
so if you use 1/8 or 3/16 inch thick material you should be fine.
hth,
  • diego092409
19 Sep 2014 13:10
#648080
So, I need to find some sch 10 or Sch 40 Seamless Carbon Steel Pipe. It might look better anyways, more natural. I like the formed tubing gussets that they have for the butt joints. Now I can search the webs looking for that...
2015 BMW K1600GT
  • Nebr_Rex
  • Nebr_Rex's Avatar
19 Sep 2014 18:12
#648105
Sch 40.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: PLUMMEN
  • diego092409
20 Sep 2014 19:21
#648226
I work in industrial piping construction. I remembered as I was out riding today that they make something called a nozzle reinforcement saddle. I just have to figure out what nominal size pipe to use. The reinforcement saddle will help with the butt joint.
2015 BMW K1600GT
