KZ200 front brake caliper swap
  • Boudewijn
  • Boudewijn's Avatar Topic Author
  • I like to tinker
19 Aug 2014 04:19
#644435
So I found this guy on youtube:
He hasn't replied yet but the story is that this gentleman mounted a KZ650 caliper on his KZ200.
There are no further detaisl so I was wondering if somebody from this forum knows if it will fit plug and play.
It doesnt seem like the guy in the video used a bracket or something to make it fit.
There are some threads on this forum about converting the cable operated brake into a hydraulic operated but most of the threads died and never showed their results.
1983 KZ200
1993 Jawa 640
1989 Honda CB-1
Opinions are like assholes. Everybody's got one and everyone thinks everyone else's stinks. :-)
  • Boudewijn
  • I like to tinker
Re: KZ200 front brake caliper swap
21 Aug 2014 13:01
#644707
Anyone?
1983 KZ200
1993 Jawa 640
1989 Honda CB-1
  • Boudewijn
  • I like to tinker
09 Nov 2014 15:39
#653261
Quick update. I found a 43041-030 caliper that came from an KZ750B and I'm going to try to make that fit.
Last week I bought a cheap brake set from a gt550 but that wont fit because the brake pads are too small for the kz200 disk/rotor.
Hope to bring the good news in a couple of weeks.
1983 KZ200
1993 Jawa 640
1989 Honda CB-1
  • AKohler883
  • AKohler883's Avatar
26 Jan 2015 13:10
#659807
did it work ?
1978 KZ200
  • Boudewijn
  • I like to tinker
18 Feb 2015 11:00
#661978
Unfortunately not yet. The caliper from the Kz750 is about 4 milimeter too big and hits the fork.
The kz750 mounting holes (where the calipers mounts to the frame) do not line up on the fork. So I tried to make the kz200 bracket fit onto the kz750 caliper. To my surprise the caliper does fit onto the kz200 bracket but because the kz750 is a bit different it doesent bolt onto the fork because the caliper is just a little bit too big.
So i've got to make a bracket myself. I'm not sure how I'm gonna make that happen yet.
1983 KZ200
1993 Jawa 640
1989 Honda CB-1
  • dragonov_elite
  • dragonov_elite's Avatar
10 Jun 2015 09:05
#675996
Have you had any success with the brake swap yet?
  • Highwaytohellsydney
  • Highwaytohellsydney's Avatar
19 Nov 2015 01:24 - 19 Nov 2015 01:25
#699308
Hi , just joined today :) I'm doing a z200 cafe racer , almost done , will post some pics soon , bought new front brake pads and had disc machined and it still won't stop !!!! Im going to look into a hydrolic conversion next week , will keep you posted if I have any luck
Last edit: 19 Nov 2015 01:25 by Highwaytohellsydney.
  • Trackerrrr
  • Trackerrrr's Avatar
24 Nov 2015 12:22
#700341
Have you taken the caliper apart and cleaned all the moving parts? I just did this on my '78 KZ200 and all the old lube/grease was causing the auto adjuster to stick and not work.
Chris
  • Boudewijn
  • I like to tinker
25 Nov 2015 12:12
#700510
I haven't tried to swap the caliper yet unfortunately.
But I did lubricate the brake cable with some engine oil and re-routed the cable so there arent too sharp bends in it, that really helped. it is drivable now.
When I do eventually make the caliper swap I will keep you guys posted. I promise!
1983 KZ200
1993 Jawa 640
1989 Honda CB-1
  • Dads Zed
  • Dads Zed's Avatar
09 Aug 2018 19:47 - 09 Aug 2018 19:51
#788587
Hi All, I've owned my Dad's KZ200 since I bought it off him in early 90s to commute with. I've had it in the garage and in boxes unused for about the last 20 years and I've finally got round to bringing it back to life. As it was a boring commuter bike with a serious lack of following or street "Cred", I've decided to convert it into a "Flat Tracker". Like the other previous posts I want to convert the front brake as I nearly ended up rear ending a car on my last trip out due to the shocking poor front cable calliper. Unfortunately, no one has come back with an easy viable solution as to what they did. I have researched as best I can with regards to the Z650 calliper swap with or without the bracket but the measurements don't seem to tie in from what I have been told? If anyone has done this I would be very grateful. My other option is to change the front forks complete with Drum, wheel Speedo-drive etc etc with something else, but that starts another whole world of problems and research and I would like to keep the original front end if possible. Any help or ways forward would be gratefully received. Thanks in Advance
Last edit: 09 Aug 2018 19:51 by Dads Zed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Aug 2018 19:56
#788589
Maybe a KZ 400 front end?
  • martin_csr
  • martin_csr's Avatar
10 Aug 2018 05:37 - 10 Aug 2018 05:38
#788598
By Dads Zed:
Does your bike have a Fr Drum brake? What year & model is it?
The KZ200As I checked at Partzilla have a cable operated Fr disk brake.
Last edit: 10 Aug 2018 05:38 by martin_csr.
