3" lowering shims install?
  • Serpent7
  • Serpent7's Avatar Topic Author
  • Nothing professionally, only for fun...
02 Mar 2014 12:57
#623908
I have a '79 KZ1000 Shaftie, and tomorrow I may get some time (all day) in the garage. Was going to tackle a few things on my bike (rear turn signals, handle bar adjustment, and install 3" lowering shims) :woohoo:
How hard is the install? If I jack up the bike on a bike jack, will all the pressure be off the fork spring, or will it still be dangerous taking it off? Any other issues with this install?
Thanks,
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
Re: 3" lowering shims install?
02 Mar 2014 14:12
#623917
3" lowering shims?? I don't know how those lowering shims work. Does that mean you plan to lower the front end by 3"? I don't have the specs for your bike, but my K650 has 5.5" of total front fork travel. If yours is similar, and you reduce it by 3" that leaves precious little suspension travel. Won't the front forks bottom out when you hit a bump or brake hard? Seems like that could easily lead to a loss of control. Also, if it only leaves 2.5" or so of fork stroke wouldn't the forks need to be super-stiff so as not to bottom out even on little bumps? Seems like that would impair both handling and comfort. Other factors to consider include the pipes or frame bottoming out on the road at speed bumps or other irregularities in the road and the potential for the front fender / wheel to hit the exhaust headers during suspension compression. I'd be very careful about losing that much suspension travel if that would be the result of using lowering shims. Ed
The following user(s) said Thank You: Serpent7
  • TexasKZ
  • TexasKZ's Avatar
02 Mar 2014 21:57
#623979
What Ed said plus yes, there will be tension on the springs. How much is impossible to say, so be very careful. If you follow the directions in the factory shop manual, you should be fine.
What sort of shims will lower the bike?
  • TexasKZ
  • TexasKZ's Avatar
02 Mar 2014 22:16
#623981
Here's an interesting article on the subject.
www.sportrider.com/tech/146_0210_lowering_your_bike_safely/
  • Nebr_Rex
  • Nebr_Rex's Avatar
03 Mar 2014 04:06
#623986
Serpent7 wrote: I have a '79 KZ1000 Shaftie, and tomorrow I may get some time (all day) in the garage. Was going to tackle a few things on my bike (rear turn signals, handle bar adjustment, and install 3" lowering shims) :woohoo:
Thanks,
Organ donations are in someones future. :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: l
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Serpent7
08 Mar 2014 06:46
#624498
First off, thanks for all your concerns about my well-being. I appreciate life and don't plan on passing anytime soon...
Second of all, if you don't try something how do you know it will work or not? 3" fork lowering shims are made by Shiltz racingI believe and are $18+. I'm building my KZ for looks first. I do not ride it often (maybe once a week; 1-2 miles). I have an idea of how I want it to look in my head and it's going to end up that way as long as I own it no matter what.
Third of all, I posted this because I'm going to hopefully start this project today and wanted to know what I'm up against as far as installation. :P
19 Audi Q5
73 Volkswagen Thing
  • Serpent7
08 Mar 2014 06:51
#624499
TexasKZ wrote: Here's an interesting article on the subject.
Nice artical.
19 Audi Q5
73 Volkswagen Thing
  • turboking
  • turboking's Avatar
08 Mar 2014 08:28
#624507
i know schnitz use to sell 1" or 2" lowering spacers for a Z/kz......I think they were made by MANLEY i do not see them available any longer.....they were 1" or 2" aluminum tube.....you do have to disassemble the tubes to install...... :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • kzz1king
  • kzz1king's Avatar
08 Mar 2014 13:42
#624535
I used the 1 inch. I raised the tubes in the trees a bit also but didnt like it. 1 inch worked well with my slightly lowered rear.
Wayne
turboking wrote: i know schnitz use to sell 1" or 2" lowering spacers for a Z/kz......I think they were made by MANLEY i do not see them available any longer.....they were 1" or 2" aluminum tube.....you do have to disassemble the tubes to install...... :S
Home built KZ1000 turbo setup
  • P21
  • P21's Avatar
08 Mar 2014 18:10
#624565
the back end of bikes not going to like that not on a shaftie
but then again live and learn
good luck
Kawasaki KZ 1000 Police (2002) P21
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
08 Mar 2014 18:59
#624567
You can get 1 inch by loosing the triple tree bolts and sliding forks up on the tree 1 inch.
I installed 2 inch spacers on mine for a total of three inches.
I Ended up going to two, as the forks felt to harsh.
  • Serpent7
18 Mar 2014 05:49
#625623
They are without a doubt, 3"… I'll post pics later on today. Never got a chance to install them yet. "Hunny do" list, and 8 month old are priority. Maybe one day this week, I'll get into the garage.
19 Audi Q5
73 Volkswagen Thing
