3" lowering shims install?
- Serpent7
- Nothing professionally, only for fun...
Re: 3" lowering shims install?
18 Mar 2014 05:56P21 wrote: the back end of bikes not going to like that not on a shaftie
but then again live and learn
good luck
Thanks for the heads up. I was told my bike wouldn't like 11.5" rear aftermarket shocks from a HD Sportster, and its never rode better! Now it's time for the front. I was thinking about getting, 10.5", or even 10" rear, aftermarket shocks after I lower the front 3". If it doesn't work out, then I'll send the forks off to a machine shop. Its going to be 3" lower in the front, regardless. I think you guys will like my finished project!
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
73 Volkswagen Thing
- Serpent7
18 Mar 2014 05:574TheKZ1000 wrote: You can get 1 inch by loosing the triple tree bolts and sliding forks up on the tree 1 inch.
I installed 2 inch spacers on mine for a total of three inches.
I Ended up going to two, as the forks felt to harsh.
If the ride is too harsh, then I'll just cut the fork springs...
19 Audi Q5
73 Volkswagen Thing
73 Volkswagen Thing
- zukdave
18 Mar 2014 09:41
2" in the back and 3" in the front your header's gonna hate you.
On mine with 10" strut's and the fork's slid to the bar's I was hittin
the header a lot that's why I did the sidewinder header.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: Serpent7
- DesertKZ
18 Mar 2014 14:31
I removed the upper springs on my Shaftie and replaced it with some spacers, forgot how long. I just played with it until I liked the height. Bike rides and handles fine and I'll do 150 mile trips no prob on them.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- slayer61
- KZR FLAG RELAY CARRIER #62
18 Mar 2014 14:45 - 18 Mar 2014 14:46Serpent7 wrote:4TheKZ1000 wrote: You can get 1 inch by loosing the triple tree bolts and sliding forks up on the tree 1 inch.
If the ride is too harsh, then I'll just cut the fork springs...[/quote]
It has been my experience that if you shorten the spring, it gets firmer, not softerjust sayin'
Last edit: 18 Mar 2014 14:46 by slayer61.
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
18 Mar 2014 20:35 - 18 Mar 2014 20:37
Two inch is good for the street. But I hate soft front ends.
Three drag only. Too low
Just remember that if you install 2' spacers your not gonna get lowered 2".
Your gonna get 2" of PRELOAD added to the spring stack.
In stead of spacers I have used 6' sections of a dual rate spring pack.
Soft for 1"of travel then hard.
As you increase the preload you stiffen and lessen travel.
And yes as you increase preload it will get harder to put together.
The easiest way to do those is this...
Place fork on a floor jack next to a wall and mark top of fork on wall.
Now build an upside down shelf bracket to put the top of the fork on by jacking up.
I used 2 x 4s. Screw it temporarily to the wall real good.
Jack up the fork to compress it on the bracket and loosen the top nut while compressed.
Reassemble the same way.
You will have to completely disassemble to do this as the spacer goes on the bottom (rebound) spring.
You can always shorten the spacers if needed.
I've seen guys use PVC pipe for this though I wouldn't.
Attachment Copyofearnhardt-footer.jpg not found
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Last edit: 18 Mar 2014 20:37 by gearheadmm.
- Serpent7
20 Mar 2014 07:49zukdave wrote: 2" in the back and 3" in the front your header's gonna hate you.
I have a sidewinder header installed...
19 Audi Q5
73 Volkswagen Thing
73 Volkswagen Thing
- Serpent7
20 Mar 2014 07:54gearheadmm wrote: Two inch is good for the street. But I hate soft front ends.
I like this idea…. Hmmmmm. Going to try my 3" spacers first. If they don't work to my liking, then I'll try this!
19 Audi Q5
73 Volkswagen Thing
73 Volkswagen Thing
- zukdave
20 Mar 2014 20:34
The spacer kit he's talking about go on the damper rod's
and stop the fork from fully extending shortening the fork..
As for spring's they'll be three inch to long so cut two inch off them
adding one inch of preload. to stiffin them.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- ed spangler
- Tennessee Z
21 Mar 2014 03:27 - 21 Mar 2014 03:29Serpent7 wrote:P21 wrote: the back end of bikes not going to like that not on a shaftie
good luck
I would Like to see pics of this work in progress!!
So, can you post pics of the Rear shocks you used? Is the rear rim/ tire stock? or......... did you use a 16" rear rime / tire?
Sounds interesting, and Look forward to ride report after mods!
Just Curious, thats me!
Regards
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Last edit: 21 Mar 2014 03:29 by ed spangler.
- Serpent7
24 Mar 2014 13:18zukdave wrote: The spacer kit he's talking about go on the damper rod's
Thanks ZukDave! Sounds like you have experience with this lowering kit. What am I up against as far as installing it? I tried to take my left, and right engine covers off last night and was not too successful… Any insight you could give would help greatly.
19 Audi Q5
73 Volkswagen Thing
73 Volkswagen Thing
- Serpent7
24 Mar 2014 13:23ed spangler wrote:Serpent7 wrote:P21 wrote: the back end of bikes not going to like that not on a shaftie
good luck
When I get home, I'll dig up some info. on my purchase. I'll snap some pics too and post.
Regards
19 Audi Q5
73 Volkswagen Thing
73 Volkswagen Thing
