Hole in my frame, what to do?
- tommyboah
09 Dec 2013 13:01 - 09 Dec 2013 13:02
I've been going over my frame and noticed that there was an uneven spot on it. The spot is in the lower front part of the frame, in front of the kick stand. Poked at it with a screw driver and things started chipping off. It seems as if water has been stuck inside the frame and rusted it from the inside? There is now a hole in the frame
What should i do with it? and is there any special care that should be taken for the rest of the frame since water has rusted a hole in this part? I ground of the paint and took a deeper look into the situation:
I have no experience with this and need some advice. Should i take it to a machine workshop and have someone reinforce the frame, or should i just weld shut the hole myself? I am a little sceptical about doing the welding myself.
Attachment IMG_1963.JPG not found
Attachment IMG_1966.JPG not found
.Tommyboy
Last edit: 09 Dec 2013 13:02 by tommyboah. Reason: Missed out some info
- Stazi
Re: Hole in my frame, what to do?
09 Dec 2013 13:17
I'd cut it back a bunch and then either replace the section or cover it with a plate welded over it
82 KZ1000-K2 LTD
- dkoz
09 Dec 2013 13:21
for me that would be a ,,, take to a professional job,,.. have em go over the whole frame .you don't want that thing to crack on you while ridding...
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
09 Dec 2013 13:43
me personally.
i would use a burr on a die grinder and start grinding the hole out until i had it to the same wall thickness as the rest of the tube.
then section a piece of tube and weld it in and blend the welds out to make it look as if i had never been there.
or you can do like these guys did and remove all of the lower tubing and replace it with chro-mo tubing.
- undiablo
09 Dec 2013 18:01
Please do as 531blackbanshee told you, is a good option a mechanical result is optimal. You should use a TIG welding machine.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- 4TheKZ1000
- Nebr_Rex
09 Dec 2013 18:32dkoz wrote: for me that would be a ,,, take to a professional job,,.. have em go over the whole frame .you don't want that thing to crack on you while ridding...
+1
That's what I would do if I wasn't that professional.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- tommyboah
10 Dec 2013 02:55Nebr_Rex wrote:dkoz wrote: for me that would be a ,,, take to a professional job,,.. have em go over the whole frame .you don't want that thing to crack on you while ridding...
+1
I've decided to bring the frame over to a qualified professional tomorrow to get it sorted out. Wouldn't want it to crack when riding, I take no chances on this.
Thanks for the advice from all of you. I will post what my solution is when I have it fixed.
.Tommyboy
10 Dec 2013 05:28
let us know how this turns out.
because sadly this is not all that uncommon of a problem and is only going to be more of an issue as these bikes age.
- floivanus
10 Dec 2013 06:21
Leon, do you think there would be a big benefit to chrome molly down tubes being used to replace damaged ones, what type of bender would need to be used?
Not to hijack of course
Past; 78 kz1000, 83 kz550
Andrew
Andrew
11 Dec 2013 06:30 - 11 Dec 2013 06:31
you could gain some strength and lose some weight using chrome-moly.
i have a homemade bender i bend 1 " .083 with manually.
but you can't go wrong with the
www.jd2.com/p-32-model-3-bender.aspx .
Last edit: 11 Dec 2013 06:31 by 531blackbanshee.
- Puffin
12 Dec 2013 06:11
yes unfortunately a common problem with older bikes
but an easy enough fix as others have said cut it back to good metal and long as your happy with your welding skills you can fix it yourself. cut a patch from tube which fits well and weld it in place.
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
