My chain touches the floor .
- Schmeck
22 Nov 2013 15:39
So I bought this 96 link 630 chain along with a 32 tooth rear sprocket. The new chain fits the rear sprocket but on the front it can slide side to side . My current chain is 102 links or whatever stock is. The new chain is 96 links but clearly longer ( see pictures) then the original chain . New is gold old is rusty. They both seem the same width on inside but the distance between rollers is more on the new chain. Is my original chain a 530? The new chain is alot bigger considering it has orings and old doesnt. Anyone else run into this problem? btw chain in my hand is what came on the bike .
Attachment image_2013-11-22.jpg not found
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- Schmeck
Re: My chain touches the floor .
22 Nov 2013 15:41
Aplogies for all the topic posts not sure what happened it just put multiple ones .
- Schmeck
22 Nov 2013 15:45
chain in hand ( didnt attach before for what ever reason )
22 Nov 2013 16:19 - 22 Nov 2013 16:22
630 is 3/4" between pins.
530 is 5/8" between pins.
Chain widths should be the same, unless one has o'rings and the other doesn't, in which event the o'ring chain is wider.
Last edit: 22 Nov 2013 16:22 by Patton.
- Schmeck
22 Nov 2013 17:01
The new chain is an oring chain but I went down 6 links and the chain turns out to be longer ? Is there a difference between oring chain length and non oring chain length?
22 Nov 2013 17:35Schmeck wrote: The new chain is an oring chain but I went down 6 links and the chain turns out to be longer ? Is there a difference between oring chain length and non oring chain length?
O'rings don't affect chain length.
Perhaps the new 630 chain has more than 96 links.
22 Nov 2013 18:12 - 22 Nov 2013 18:19
For the 1979 Kawasaki KZ750-B4 at hand,
Z1 Enterprises lists 106 link 530 for KZ750 twin:
www.z1enterprises.com/ItemDetails.aspx?i...&item=LA530XSOZ1-106
106 link 530 is 66.25" long
102 link 530 is 63.75" long
96 link 630 is 72" long
88 link 630 is 66" long
89 link 630 is 66.75"
To get length of a 630, multiply the number of links times 3 and divide by 4.
Example: 96 x 3 ÷ 4 = 72
To get length of a 530, multiply the number of links times 5 and divide by 8.
Example: 106 x 5 ÷ 8 = 66.25
Last edit: 22 Nov 2013 18:19 by Patton.
The following user(s) said Thank You: P21
22 Nov 2013 18:15
A 630 doesn't fit onto a 530 sprocket (doesn't mesh).
A 530 doesn't fit onto a 630 sprocket (doesn't mesh).
- P21
22 Nov 2013 18:17
Patton you beat me to the math but you are correct Sir
glad to have you on board
Kawasaki KZ 1000 Police (2002) P21
- P21
22 Nov 2013 18:21
96 x .750=72"
102 x .625 = 63.75
102 x .625 = 63.75
22 Nov 2013 18:53P21 wrote: 96 x .750=72"
102 x .625 = 63.75
Yes
Examples:
A piece of 630 chain is 72" long.
How many links does it have? (No counting allowed.)
72 ÷ .750 = 96
A piece of 530 chain is 72" long.
72 ÷ .625 = 115 (rounded from 115.2)
Meanwhile, the individual link counters in the other room have to keep starting over and over again because they lose count :blink: somewhere around link number 42 -- or was that 43 ? :lol:
22 Nov 2013 19:54
It's a little difficult for me to understand what you are trying to do or why you would buy a 630 chain for your bike. Have you made a bunch of mods? The stock chain for the KZ750 twin is 530 with 106 links, the stock rear sprocket has 38 teeth and the stock engine sprocket has 16 teeth. Is there a reason you don't want to use components that adhere to the stock specs? Ed
