Swingarm Conversions
- KawiConvert
06 Nov 2013 22:19 - 18 Nov 2013 07:55
Here is a list of swingarm pivot to axle lengths for swing arm swaps that people may be considering. I collected these for my KZ650 but the lengths are still useful for others.
Swingarms axle to pivot distances / Pivot mount width / Hub mount width
ZR550 - 20.5" / 9"
ZX636 (2003) - 22" /
ZR750 (2000) - 21" /
GPZ750 - 20.5" /
ZX600 (1986) - 20" / 9.125"
GSRX750 (1990) - 20.7" (in the forward axle position) / ?
ZRX1100 (1999) 20.7"/9,25" (width not confirmed)
GS1100 21.25" (not confirmed) / 8.6875" / 10.25"
CB1000 (1994). 23" / 11" /
Any others that I've missed that are common for swapping in on the KZ's?
ZR550 - 20.5" / 9"
GPZ750 - 20.5" /
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Last edit: 18 Nov 2013 07:55 by KawiConvert.
- StreetfighterKz
Re: Swingarm Conversions
07 Nov 2013 04:11
The oil cooled Gsxr swingarms can be made to fit quite easily and the 750's arm won't lengthen the bike too much if at all. If you want to keep the twin shocks then it'll just be a matter of welding on some shock mounts which I believe Z1Enterprises can get.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: KawiConvert
07 Nov 2013 06:39 - 07 Nov 2013 06:41
No eBay APP ID and/or Cert ID defined in Kunena configuration03-04 zx6/636 is nice later model stuff to use as well,like dnels bike..
that gets you into some nice late model brakes wheels and suspension.
you gotta have some machine work done on the pivot and weld shock mounts on and modify the caliper mount to clear the shock.
but,the swingarms go for cheap and the machine work isn't that expensive.
and you get to keep it kawi !!!!!!!!!!!! :evil:
Last edit: 07 Nov 2013 06:41 by 531blackbanshee.
07 Nov 2013 07:39
i don't recall how much longer the arm is than factory.
a little slice and weld gets the caliper out of the way.
07 Nov 2013 07:55
sorry convert,
i just did the work i don't have access to any of them.
you might pm D'nel.
you might pm D'nel.
- Haybus
- Big Al
10 Nov 2013 10:37
The ZX6 arm added 2" over stock length to my bike. Leon steered me towards that arm and I'm glad I took his advice. Super easy to convert.
Alan
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
- zukdave
10 Nov 2013 12:34 - 10 Nov 2013 12:39
I run an 83 GPz750 arm on my F1 that's 2 1/2" longer then the stock arm.
Easy swap I trimmed about 1/16" off each end of the tube and the drilled the frame to fit the GPz bolt.
Z1R rear hub with a cut down disk to fit the GPz caliper and made spacer ring's to fit GPz bearing's
for the GPz axle bolt.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 10 Nov 2013 12:39 by zukdave.
- zukdave
11 Nov 2013 01:17
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KawiConvert
11 Nov 2013 05:25Ok good I'm hoping to get at least a 160 -17 on the back in place of the 130/90-16 that's on there now.
- KawiConvert
15 Nov 2013 20:03
Gave up on the GPZ750 arm when I couldn't find a chain guard for them. Figured I'd keep looking. Right now I'm waiting back for length on a GSRX750 arm and for the ZRX1100 arm.
Edited the first post to have the useful information in it.
- Puffin
16 Nov 2013 07:26 - 16 Nov 2013 09:49
The GSXR750 arm is 52,5cm long, forward adjuster position, i do not have a pivot measure but could take one on Sunday. Are you measuring with the dust caps in place ?
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
Last edit: 16 Nov 2013 09:49 by Puffin.
- KawiConvert
16 Nov 2013 09:15Puffin wrote: The GSXR750 arm is 52,5cm long, forward adjuster position, i do not have a pivot measure but could take one on Sunday. Are you measuring with the dust caps in place ?
Hard metal to hard metal. If the dust caps contain washers then yes please include them. Thanks!
