1975 z1 900 front end upgrade
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: 1975 z1 900 front end upgrade
09 Sep 2013 10:26
#605670
I invested in a little siphon feed sand blaster. It has become an indispensable tool fixing up these old bikes.
Try Arrow Plating in Texas. I haven't used them yet but I read good things and will be using them next. You should collect all of your old hardware and look for some period hardware lots on Ebay to add to it for extra.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
The following user(s) said Thank You: mardimus
  • byars
  • byars's Avatar
09 Sep 2013 12:47
#605690
Zinc plating for rusty bolts.
Z1 Car tire conversion dragbike (SAM WILLS)
81 Gpz (84 1170 motor)
  • MDawnz1
  • MDawnz1's Avatar
11 Sep 2013 04:10
#605974
I used "gun kote" on my engine covers after sandblasting.
It's just about black and is the toughest stuff you can ever find.
Heat? no bother,,
Dirt? wont stick,,
Oil? wipes off and makes it shinny,,
Its what the US mil. puts on its air cooled weapons.
1974 Z1a, still 903
The following user(s) said Thank You: bluezbike
  • bluezbike
  • bluezbike's Avatar
12 Sep 2013 00:17
#606120
Where do you find the gun-kote....tried my local NAPA they didn't know about it.
79 KZ 1000 LTD
  • mardimus
  • mardimus's Avatar Topic Author
12 Sep 2013 00:27
#606125
I found it online at a few places but there is some responses on other forums and people who have used it having issues with the epoxy resin that is in it reacting with UV light. Any thoughts on this?
I bought the POR15 rust preventative paint and two 220z cans of the spray on chassis paint from my local Wesco store and they loved the stuff. I am painting my frame and other parts this week as soon as I get all my sandblasting done.
  • DoctoRot
  • DoctoRot's Avatar
12 Sep 2013 02:04 - 12 Sep 2013 02:11
#606134
mardimus wrote: I found it online at a few places but there is some responses on other forums and people who have used it having issues with the epoxy resin that is in it reacting with UV light. Any thoughts on this?
I painted my engine cases with the KG gunkote and am very satisfied with the results, however the engine has never really seen the sun as i haven't finished the bike yet. all coatings/paints are susceptible to UV damage, some just take longer than others. even UV resistant epoxies will break down after 50+ years of constant exposure. im curious to see the forums you found where they are having trouble with UV exposure, as I have yet to find any negative reports on the gun kote where the surface was prepared as per the manufacturers directions (either sandblasted or applied over anodization for aluminum)
BTW you can buy gun Kote straight from KG coatings, or you might have luck at a specialty gun shop. DO NOT buy the brownells gun kote aersol can. its not the same.
www.kgcoatings.com/coating-protective-products.php
Last edit: 12 Sep 2013 02:11 by DoctoRot.
  • DoctoRot
  • DoctoRot's Avatar
12 Sep 2013 02:10
#606135
also when you bake it on, don't do it in your kitchen oven the black and green have lead in them. not something you want with your food.
  • MDawnz1
  • MDawnz1's Avatar
13 Sep 2013 03:40
#606266
Oh yeah, I forgot, IT JUST ABOUT MAKES YOUR PLACE UNLIVABLE,
It stinks when you cure it in a home oven.
It looks like they now make an air cure one also.
I would look for an electric oven on freecycle.org, use it in the back yard then recycle it.
Does anyone know if you can still get it in spray cans?
Mike
1974 Z1a, still 903
