Anybody Ever Polish a GS1100 Swingarm?
- 79MKII
- Love Them Kaws!
18 Jul 2013 23:14
Hello All,
I'm working on my '78 KZ1000 A project and I've got a GS1100 swingarm for it. I've got everything ready to go now....reconditioned / painted / new: All bearings, sleeves, shocks, chainguard, brake caliper, 3.5" aluminum rim laced to a stock hub with a 150/70 tire, etc...
I'm ready for final assembly but I'm having a real hard time refinishing the swingarm. It's the last piece I need to clean up. There's a factory silver coating that won't come off! I've tried chemical strippers, sanding, etc...with no luck. I wanted to polish it but I'm thinking about painting it black or silver.....which I swore to myself I'd never do to an aluminum part. Or, I'd send it somewhere to be polished if I could find some place to do it. Nobody ever gets back to me?
Any thoughts??
Thanks
Thanks
The Kaw List:
- steell
Re: Anybody Ever Polish a GS1100 Swingarm?
18 Jul 2013 23:54
A angled die grinder with a sanding disk will make short work of that silver coating. I just did a ZX11 arm and it was the same way.
- 79MKII
- Love Them Kaws!
19 Jul 2013 09:05
I do have an angle grinder...will give it a try. I'm just concerned that it will leave the aluminum too rough and create a lot of extra work for getting it polished. I guess I don't have much of a choice though because that silver coating is tough stuff!!
The Kaw List:
- turboking
19 Jul 2013 09:15
I've done them by sanding with wet and dry sandpaper. lots of work though :S ....... after I did my last one a guy told me E Z off oven cleaner would remove the anodize :dry: ...... although I never tried it
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- 79MKII
- Love Them Kaws!
19 Jul 2013 09:30
I used a chemical stripper on a brake caliper I was rebuilding and it bubbled the paint right off....the same stuff didn't do anything to that silver stuff! Oven cleaner might be worth a try.
The Kaw List:
- Grumpy Ole Artist
- Eschew Obfuscation!
19 Jul 2013 11:54
Dunno what's on your swing arm, but an old signwriters' trick...the Lye in "Easy-Off" will attack sign paint (Enamel), yet leave factory paint (Laquer, Base/Clear) alone...Worth a try, but wear gloves and eye protection. The Lye WILL eat skin!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- Kidkawie
- I bleed premix
19 Jul 2013 12:14 - 19 Jul 2013 12:16
It's clear anodize people.
The oven cleaner (EZ Off) can remove it but it will leave a black residue. Use the drain cleaner (lye) in the photo. You get it from Lowes in the plumbing section. Just fill a plastic tub with water and add about a cup of lye to start. It's going to be hard to see results since it's clear anno you're removing. I would let it soak for 30 minutes, then see if you can easily polish a small section with some fine steel wool. If it's the same, add another cup of lye and do another 30 minutes. Might bubble a bit, that's ok.
I picked up on these tips from a BMX site. They're constantly dealing with rust, anno, old chrome, etc.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 19 Jul 2013 12:16 by Kidkawie.
The following user(s) said Thank You: guitargeek
- 79MKII
- Love Them Kaws!
22 Jul 2013 15:50 - 22 Jul 2013 15:51
This is a thick silver coating, not just clear anodize. I'm guessing it's paint since I don't think they were powder coating back then. Whatever it is, it's on there good. I've got to get to the bare aluminum to polish it.
By the way, I heard back from a local polishing place.....$375 to do the arm! :ohmy: Does that seem right to you guys? I can buy another swingarm for that kind of money. Wow......
The Kaw List:
Last edit: 22 Jul 2013 15:51 by 79MKII. Reason: forgot pic
- turboking
22 Jul 2013 16:45
i think it's the clear anodize you are calling a coating of silver......$375 seems like a lot. but after you do one it may have been money well spent. :whistle:
btw you only have to polish what will be seen...... not the under side or inner....lol :woohoo:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- Kidkawie
- I bleed premix
22 Jul 2013 17:00 - 22 Jul 2013 17:04
Thats anno.
I did one for one of my KX builds once. Like turboking said, just do what you see. In my case, the center section is cast and it was painted originally. So I just polished the extrusions (arms) and painted the center silver.
1975 Z1 900
2004 KX125
2004 KX125
Last edit: 22 Jul 2013 17:04 by Kidkawie.
- Old Man Rock
23 Jul 2013 00:11 - 23 Jul 2013 00:14
ZX636 Swing-arm count.... Black hard as hell to get off rims and swing-arm....
Here's what I used after trying several brands of stripper to no avail other than a mess....
Then buff the hell out of her..... Brown tripoli then white compounds, buff disk/pad on end of drill. Yes, it took some time, Ok was a PITA but was worth it...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 23 Jul 2013 00:14 by Old Man Rock.
- 79MKII
- Love Them Kaws!
23 Jul 2013 09:31 - 18 Jan 2014 10:27
If the heavy silver is anodize, it makes sense then why the stripper doesn't touch it. I need something caustic like easy off or lye, as has been mentioned.
I took Steele's suggestion to use an angle grinder and did a lot of sanding last night. It worked great on most of it but there are a lot of nooks and crannies that I can't reach. I might need the oven cleaner for those areas.
OMR - Wow, that ZX6 stuff looks great...thanks for the tips. Any idea where I could find abrasive wheels like those? Home Depot or Lowes maybe?
The Kaw List:
Last edit: 18 Jan 2014 10:27 by 79MKII. Reason: sic
