how the heck does the air filler work 16" rim
  • donthaveakawman
  • donthaveakawman's Avatar Topic Author
04 Apr 2013 18:38 - 04 Apr 2013 18:47
#580576
I've got this tiny 16" wheel on the back of my motorcycle and the air filler thing is a real problem for me.
Attachment 130404_214.jpg not found
Last edit: 04 Apr 2013 18:47 by donthaveakawman.
  • gengomerpyle
  • gengomerpyle's Avatar
Re: how the heck does the air filler work 16" rim
04 Apr 2013 18:55 - 04 Apr 2013 19:00
#580580
what are you trying to use to put air in it? get one of these
www.dreamstime.com/stock-photography-tir...-chuck-image19432922
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
Last edit: 04 Apr 2013 19:00 by gengomerpyle.
  • wireman
  • wireman's Avatar
04 Apr 2013 20:26
#580585
Make sure its the valve stem and not a bead lock :)
The following user(s) said Thank You: peter1958
  • racer54
  • racer54's Avatar
04 Apr 2013 20:53
#580589
That's a fairly tight area to work in also. Instead of just reaching in there with your air chuck from the side, you will probably have to come in from the back so your hand fits in between the brake disc and sprocket. Not much room but that's the easiest way to reach the filler tube. Go in parrallel to the tire not 90* to it.
  • testarossa
  • testarossa's Avatar
04 Apr 2013 22:46
#580611
wireman wrote: Make sure its the valve stem and not a bead lock :)
Why does this wheel have three valve stems???? :P
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • wireman
  • wireman's Avatar
04 Apr 2013 22:57
#580614
Just trying to cover all the bases considering the source of the question. :woohoo:
04 Apr 2013 23:03
#580615
I always put 12 PSI in each of the three; I figure that makes 36 PSI total. :whistle: Ed
The following user(s) said Thank You: elfmagic17
  • martin_csr
  • martin_csr's Avatar
05 Apr 2013 10:40 - 05 Apr 2013 10:44
#580682
The diagram for his rear wheel doesn't show rim stoppers (bead locks).
If you're having trouble airing it up, you could try getting an angled/long air chuck.
Do an internet image search for dual head air chuck to see what I'm talking about.
Or next time you have the tire off, install an angled valve stem.
Last edit: 05 Apr 2013 10:44 by martin_csr.
  • donthaveakawman
09 Apr 2013 00:22 - 09 Apr 2013 00:24
#581321
it's really awkward- 16 on the back and 19 on the front. I am holding on for dear life trying not to fall off the back with people looking at me like it is a "Big Wheel" with only two tires.
Attachment bigwheel.jpg not found
Last edit: 09 Apr 2013 00:24 by donthaveakawman. Reason: photo upload failed-wikimedia commons
  • martin_csr
09 Apr 2013 10:14
#581363
Because you can't air up the tires? Or is there some other problem? My bike has basically the same wheels which aren't problematic.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 Apr 2013 11:25
#581377
Nice, half in each one.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • donthaveakawman
09 Apr 2013 21:22
#581477
what would it take to put an 18" wheel from a kz750 e1 on this?
