how the heck does the air filler work 16" rim
- donthaveakawman
04 Apr 2013 18:38 - 04 Apr 2013 18:47
I've got this tiny 16" wheel on the back of my motorcycle and the air filler thing is a real problem for me.
Attachment 130404_214.jpg not found
Last edit: 04 Apr 2013 18:47 by donthaveakawman.
- gengomerpyle
Re: how the heck does the air filler work 16" rim
04 Apr 2013 18:55 - 04 Apr 2013 19:00
what are you trying to use to put air in it? get one of these
www.dreamstime.com/stock-photography-tir...-chuck-image19432922
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
Last edit: 04 Apr 2013 19:00 by gengomerpyle.
- wireman
04 Apr 2013 20:26
Make sure its the valve stem and not a bead lock
The following user(s) said Thank You: peter1958
- racer54
04 Apr 2013 20:53
That's a fairly tight area to work in also. Instead of just reaching in there with your air chuck from the side, you will probably have to come in from the back so your hand fits in between the brake disc and sprocket. Not much room but that's the easiest way to reach the filler tube. Go in parrallel to the tire not 90* to it.
- testarossa
04 Apr 2013 22:46Why does this wheel have three valve stems????wireman wrote: Make sure its the valve stem and not a bead lock
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- wireman
04 Apr 2013 22:57
Just trying to cover all the bases considering the source of the question. :woohoo:
04 Apr 2013 23:03testarossa wrote:Why does this wheel have three valve stems????wireman wrote: Make sure its the valve stem and not a bead lock
I always put 12 PSI in each of the three; I figure that makes 36 PSI total. :whistle: Ed
The following user(s) said Thank You: elfmagic17
05 Apr 2013 10:40 - 05 Apr 2013 10:44
The diagram for his rear wheel doesn't show rim stoppers (bead locks).
If you're having trouble airing it up, you could try getting an angled/long air chuck.
Do an internet image search for dual head air chuck to see what I'm talking about.
Or next time you have the tire off, install an angled valve stem.
Last edit: 05 Apr 2013 10:44 by martin_csr.
- donthaveakawman
09 Apr 2013 00:22 - 09 Apr 2013 00:24
it's really awkward- 16 on the back and 19 on the front. I am holding on for dear life trying not to fall off the back with people looking at me like it is a "Big Wheel" with only two tires.
Attachment bigwheel.jpg not found
Last edit: 09 Apr 2013 00:24 by donthaveakawman. Reason: photo upload failed-wikimedia commons
09 Apr 2013 10:14
Because you can't air up the tires? Or is there some other problem? My bike has basically the same wheels which aren't problematic.
- Kidkawie
- I bleed premix
09 Apr 2013 11:25650ed wrote:testarossa wrote:Why does this wheel have three valve stems????wireman wrote: Make sure its the valve stem and not a bead lock
Nice, half in each one.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- donthaveakawman
09 Apr 2013 21:22
what would it take to put an 18" wheel from a kz750 e1 on this?
