'78 Z1R, cannot get front brake rotors off
  • newOld_kz1000
  • newOld_kz1000's Avatar Topic Author
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
04 Mar 2013 00:41
#575190
I've got to strip, clean and re-paint the stock wheels on my '78 Z1R, they came on the bike in a weird blue color.
Well I did manage to remove all the bolts that secure the 2 rotors to the front wheel.
But the rotors won't come off.
Here are photos. Couple things to note, yes I already removed some of the paint as a test to see if I had an effective agent to do so (Kleen-Strip's Paint Remover as it turns out) and yes I'm wearing flip flops there on my feet, it's over 70 degrees here in Silicon Valley. I guess high tech and snow don't mix B) B) B) B) B) B) B) B)
What is the trick to prying off these rotors? This is a stock Z1R set of wheels, just painted weird. Pulling hard on them didn't work. Using my long breaker bar to get some lever didn't work neither.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Re: '78 Z1R, cannot get front brake rotors off
04 Mar 2013 00:47
#575192
Maybe try soaking the joints between the rotor and wheel with Kroil for a couple days. Ed
  • wireman
  • wireman's Avatar
04 Mar 2013 00:52
#575194
They were probably installed when that blue paint was wet,or they just corroded together from all that fine see air out there.
Try bang on the rotors from behind with a piece of wood,you could also trying heating up rotor bolt flange area with a propane torch to get it warm then try banging on them to loosen them up. B)
  • newOld_kz1000
04 Mar 2013 00:53
#575195
650ed wrote: Maybe try soaking the joints between the rotor and wheel with Kroil for a couple days. Ed
Good deal 650, where locally can I buy that Kroil? I was in Harbor Freight the other day and didn't see any. I live near the 10th biggest city in this entire country, surely they sell that Kroil through outlets dont' they?
  • newOld_kz1000
04 Mar 2013 00:58
#575199
wireman wrote: They were probably installed when that blue paint was wet,or they just corroded together from all that fine see air out there.
wireman that is a dang fine idea, I did not think to whack them from behind. Too much sun today, my brain must be fried.
When I clean everything up real good after getting the rotors off, will I still find that I need a rubber mallet to pop them back on into place, are the stock tolerances between the rotor and hub that tight? Or if I do a good job on the clean-up, will the rotors just fall right into place with very little effort?
I don't have experience with the tolerances between a rotor and hub at all.
  • wireman
  • wireman's Avatar
04 Mar 2013 00:58
#575200
The problem is the state youre in ,not the city! :woohoo:
wd40 is probably the toughest stuff you can buy there without somebody calling the hazmat unit on ya B)
  • wireman
  • wireman's Avatar
04 Mar 2013 01:00
#575201
No once you get the corrosion cleaned out of there they will go on and off much easier :)
04 Mar 2013 01:08
#575205
While the rotors are in hand, would consider having them trued by an automotive service facility that has a flywheel grinder.
Good Fortune! :)
04 Mar 2013 01:14 - 04 Mar 2013 01:14
#575209
See info in link. Ed
kzrider.com/forum/3-carburetor/573728-78...lot-air-screw#573746
Last edit: 04 Mar 2013 01:14 by 650ed.
  • donthaveakawman
  • donthaveakawman's Avatar
04 Mar 2013 01:58
#575222
a blowtorch and a prybar would be my first best guess, but upon second look is that wheel bearing got to come out?
  • newOld_kz1000
04 Mar 2013 02:14
#575223
wireman wrote: The problem is the state youre in ,not the city! :woohoo:
I'd like to know why states with the best weather always attract large numbers of rascals. California going down the tubes, sun is out, head to the beach, the beach does not care about anything but looking good and feeling great and providing sand for motorsports fun and hot young ladies.
Plus you can ride all year round here.
The rascals ruining the state won't last forever, the beach will always be a cool place to go.
AMEN.
  • newOld_kz1000
04 Mar 2013 02:17 - 04 Mar 2013 02:19
#575224
donthaveakawman wrote: a blowtorch and a prybar would be my first best guess, but upon second look is that wheel bearing got to come out?
I'm leaning heavily in favor of new wheel bearings. As long as I'm probably going to remove them anyways for re-doing the wheels, bearings are not that much $$ and I agree, the ones in there now look their age dont they.
Patton thanks for the tip, I'll have the 3 rotors turned, I think that's what you meant, it will give a good vibration-free brake feel.
But brings up a question, I've never removed wheel bearings, do I knock them out from the opposite side, or do I need a special tool?
And I guess for installation, a rubber mallet?
Last edit: 04 Mar 2013 02:19 by newOld_kz1000.
