1981 KZ1000 CSR M1 - Front Sprocket Removal
- WABBMW
- Let The Good Times Roll !
Re: 1981 KZ1000 CSR M1 - Front Sprocket Removal
30 Jan 2013 20:04
I have done this job a couple of times, but the nut was in decent shape, so I used a socket and large breakover bar. I used an extension for the breakover bar, to gain some clearance from the engine. Then placed a cinder block + a piece of 3/4" wood beneath the bar to support it while carefully standing and jumping on the bar. To hold the sprocket from turning, I put the bike in gear and had a helper to hold down the rear brake.
The second time I did the job, I could not get the nut loose. (Some goose (me) must have over tightened the nut. Wound up grinding the nut away in two places, to a point just above the threads, so that it fractured and came loose with a socket.
I tried some heat, but worried about ruining a seal inside the transmission. I would think also that hammering on the nut might damage the bearings inside as well. This is a tough job, and young children or grandmothers should try to do it. Hell, grown men have a difficult time with it - as evidenced by this discussion.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
30 Jan 2013 20:14
I believe his bike uses a bolt rather than a nut, so cutting it off isn't an option. If nothing will grab the bolt firmly enough to loosen it welding a nut to it may be the next best solution. Ed
- donthaveakawman
04 Feb 2013 05:08
maybe there is a washer that splines in with the sprocket, it would be bent over the side of one of the flat parts of the nut.
- donthaveakawman
04 Feb 2013 05:09
you are going to need a breaker bar and a socket with someone to stand on the brakes.
- rhoadley
04 Feb 2013 17:09
There are several washers and lock plates but they have all been removed, and having somebody stand on the brake does help a lot, which I have also done. And as far as an update on removing the sprocket BOLT...it is completely and udderly rounded now. I bought that craftsment set I mentioned earlier and it still will not come off no matter how much torque I put on it. Is this bolt a counterclockwise to remove like normal? Or is it the opposite of whats normal? Thanks for the help, this job sucks.
1981 KZ1000 CSR M1 - Stock/Clean
- donthaveakawman
04 Feb 2013 20:56
get a good set of vise grips and some leverage. I used the handle of my 3 ton floor jack on the end of a ratchet I think it was 1 1/16". Or you could get a new nut and use a dremel cut off wheel to get the old one off as a last resort, you may have to cut into the threads of the sprocket shaft. there is always the option of a pickup truck and a trip to the machine shop.
04 Feb 2013 21:45
Judging by the parts diagram there's no nut to cut on the KZ1000-M1. It has a bolt holding the sprocket on. Ed
Attachment 00000_2013-02-04.jpg not found
05 Feb 2013 01:05z1wiz wrote: ...hold a much larger nut that fits completely over the bolt head in place and weld inside the nut to the bolt. Now you can easily put a socket on the nut and hit it with the impact to remove....
If the rounded bolt head is accessible to a small pipe wrench, such wrench grips tighter as more pressure is applied. Failing that, would weld on a nut per z1wiz's suggestion.
Fingers crossed that the bolt head doesn't snap off leaving the shank embedded inside the shaft.
- donthaveakawman
06 Feb 2013 05:40
I have a set of bolt/nut extractors from craftsman, i used them yesterday works great.
www.sears.com/shc/s/p_10153_12605_009520...pncode=35-32697294-2
