1981 KZ1000 CSR M1 - Front Sprocket Removal
- rhoadley
28 Jan 2013 19:52
Hello KZ Community,
I am in the process of changing out my front and rear sprockets and replacing the chain with new factory spec hardware (630 chain, same no. teeth sprockets, etc.) And I am having difficulty getting the front sprocket because the sprocket nut has been rounded pretty badly so using a socket is all but impossible. BUT! I see on the face of the sprocket nut is a notch that stretches across the entire face of the nut. Attached I have a picture of a "Bar-Tool" that comes in the factory tool kit. If I bought just this tool (for 7 bucks) is it the one that is supposed to be used to remove the front sprocket nut. Later tonight I will post a picture of the nut for clarification if needed.
Thanks in advance for the help,
Ryan
Ryan
Attachment Capture.JPG not found
1981 KZ1000 CSR M1 - Stock/Clean
- wireman
Re: 1981 KZ1000 CSR M1 - Front Sprocket Removal
28 Jan 2013 20:03
Can you get an impact socket on there and spin it off?
The following user(s) said Thank You: rhoadley
- z1wiz
28 Jan 2013 20:21
I've broke one loose with a hammer and chisel before when the nut was in bad shape.
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
The following user(s) said Thank You: wireman, rhoadley
- rhoadley
28 Jan 2013 21:13 - 28 Jan 2013 21:15
Wireman,
My sprocket nut is pretty well rounded and didn't want to make it litterally perfectly round with a slipping impact wrench. I think I'm going to Autozone to see if I can rent a simple tool like the "Bar-tool" in the picture I attached. I'll let you guys know how this is coming along.
Ryan
Ryan
Last edit: 28 Jan 2013 21:15 by rhoadley.
- 78z1Joe
- My man cave is my garage....
28 Jan 2013 23:06
Using a chisel and hammer is a good idea, z1wiz, I've done that myself. I can't remember what size that nut is but try to force, wedge or "gently " hammer a socket of a different size onto the nut. Say use a 3/4" on the nut that should be 16 mm. then use a breaker bar to try to loosen. You may need a length of pipe as an extension to the breaker bar for increased leverage. And a friend to help steady the bike.
Good Luck,
Joe
Good Luck,
Joe
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- rhoadley
29 Jan 2013 00:40 - 29 Jan 2013 00:45
Joe,
Thanks for the tip on using a chisel and hammer but I'm not sure exactly how to go about using a chisel and hammer. But does anybody know if that tool I mentioned would be normally used to take the sprocket nut off? I'm thinking of just buying that "Bar-Tool" just to make sure the job is done correctly. If its even the right tool. I can't find sh!t at my local auto-parts stores for something that could work for this job. Attached is a picture of my sprocket nut that I'm trying to get ANY torque on without using a socket or impact wrench. I really would just like to use the "channel" on top of the nut.
Last edit: 29 Jan 2013 00:45 by rhoadley.
- rhoadley
29 Jan 2013 03:52
www.sears.com/shc/s/p_10153_12605_009521...pncode=31-74754878-2
I'm thinking about this idea. Any thoughts?
29 Jan 2013 04:29
Am thinking that the item being referred to as a "Bar-Tool" is a short extension to fit over and add slight leverage to an end wrench or maybe a shock adjuster tool.
A much longer breaker-bar may be needed to loosen the counter shaft sprocket nut, which is sometimes notoriously tight and difficult to break loose.
If the nut is already sufficiently damaged to prevent gaining a hold with a socket for removal (with a breaker bar or air hammer), it's likely too damaged for adequate tightening when later reinstalling the sprocket.
Heat from a butane torch might help loosen the nut, if red lock-tite was used when assembled.
A hammer and a steel cold chisel may be used by allowing the chisel point to dig into edge of the nut while pounding on the chisel with the hammer.
Might also use a cut-off wheel or Dremel tool to carefully slice into the nut.
In any event, wear eye protection.
Here's one option for holding the sprocket in position while attempting to turn the nut.
- z1wiz
29 Jan 2013 14:51 - 29 Jan 2013 14:54
Using a hammer and chisel to loosen a rounded off nut isn't very hard to do. Don't worry about damaging the nut as you would want to replace the rounded off one with a new one anyway. Is it a nut or a bolt on that model?
Last edit: 29 Jan 2013 14:54 by z1wiz. Reason: another ?
- rhoadley
29 Jan 2013 19:56
I think I might try to use my cold chisel and hammer, I'm just very nervous about damaging something while hammering away with a chisel trying to break the nut loose. I would prefer to just torque it with that kit I found from craftsman. But I will try both and see which works first.
And on a side not. I need to determine which is the correct new sprocket nut. I have a attached a photo of both dimensions. One is 10x35 and the other is 10x39. Which one do I need? I'm trying to order all my parts while gradually working on getting the sprocket nut off.
- z1wiz
29 Jan 2013 23:15 - 29 Jan 2013 23:26
So it is a bolt, I misunderstood what you were saying. Another option if you have a welder, is to hold a much larger nut that fits completely over the bolt head in place and weld inside the nut to the bolt. Now you can easily put a socket on the nut and hit it with the impact to remove. We do this at work on rounded off bolt heads and worn out socket head cap screws.
The length of the bolt depends on your engine number.
92001 fits Up to # KZTOOJE005306
92001A fits KZTOOJE005307 and up
Last edit: 29 Jan 2013 23:26 by z1wiz.
- 4TheKZ1000
30 Jan 2013 11:51 - 30 Jan 2013 11:53
you can weld a old socket to the nut and use a impact gun....would make quick work of it.....little rough on socket though.
would be down towards the bottom of my list of things to try, sounds like your getting close to bottom..... :whistle:
Last edit: 30 Jan 2013 11:53 by 4TheKZ1000.
