Wheel Bearings - Quality...
- 4TheKZ1000
13 Dec 2012 13:27
What are the forums thought on wheel bearings?
AllBalls seems to be out front and in your face. Are there better bearings for sale or due these measure up?
I have herd some rumblings about cheap quality bearings....lasting just 10,000 miles or less.
Thanks
Thanks
Re: Wheel Bearings - Quality...
13 Dec 2012 13:52
i can't tell by looking what brand of bearings all balls is selling.
i like to go with brand names i know when it comes to bearings.
koyo,timken,skf,torrington etc.
thats my .02 .
thats my .02 .
The following user(s) said Thank You: 4TheKZ1000
13 Dec 2012 14:29531blackbanshee wrote: i can't tell by looking what brand of bearings all balls is selling.
thats my .02 .
- OnkelB
13 Dec 2012 15:04
Agree with Leon and Ed - personally I go with SKF bearings, they're readily available over here and are good quality.
No need to go to a bike shop though, with a few exceptions (such as steering stem bearings and a few engine bearings) most of the bearings used in the KZs are industry standard and can usually be found much cheaper at your local hardware store.
77 KZ 650 B1, 82 GPz 1100 B2.
The following user(s) said Thank You: wireman, 4TheKZ1000
- steell
13 Dec 2012 15:22 - 13 Dec 2012 15:27
Ceramic bearings, for ~$300-$350 for both wheels, said to be a noticeable difference in coast down.
There's a company that sells bearing they call Micro Blue, they claim to be one step below ceramic.
Or you could go with higher class bearings, like ABEC 5 or maybe even ABEC 7 (ABEC is a bearing standard), more $$ though.
A number of racers are using the ceramic bearings.
I always thought torrington was just another name for thrust bearings, not a company, so when I read the above post I googled torrington. Turns out they are a company that specializes in thrust and needle bearings, and a subsidiary of Timken.
Cool!! I learned something!
Last edit: 13 Dec 2012 15:27 by steell.
- Powerstroke_fan
13 Dec 2012 17:58
I hope all balls wheel bearing and steering stem bearings are good, I just bought some a month ago. Havent installed yet to see how they re gonna act.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- lushbaugh
- everybodys a pro......
13 Dec 2012 19:21
ive used all balls a few times and i will again, ceramics are gucci but man thats big money
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
13 Dec 2012 20:07 - 23 Jan 2013 13:42They're probably just as good as any similar type of bearing. According to the All-Balls-Racing site, their bearings are precision high speed ABEC3. You can do some searches, but I'd guess they're good bearings. I installed them on my 81 KZ650. Something I like about the kits is that they include the oil seals that you would have to otherwise purchase separately from the dealer or something. I probably wouldn't have serviced the speedo drive if not for the seals.Powerstroke_fan wrote: I hope all balls wheel bearing and steering stem bearings are good, I just bought some a month ago. Havent installed yet to see how they re gonna act.
Last edit: 23 Jan 2013 13:42 by martin_csr.
- roy-b-boy-b
13 Dec 2012 20:40
I personally don't like the rattle from the allballs steering head bearings. I use them but I don't like the rattle. I guess when they are compressed they don't rattle. Roy
13 Dec 2012 20:42Powerstroke_fan wrote: I hope all balls wheel bearing and steering stem bearings are good, I just bought some a month ago. Havent installed yet to see how they re gonna act.
I can't comment on AllBalls wheel bearings; I used Koyo (Kawasaki NOS) bearings when I replaced mine. However, I did use AllBalls tapered roller steering stem bearings in my bike and they are great. Ed
- boatdrinks
13 Dec 2012 20:43
Have All Balls in my Seca Turbo steering stem, no issues.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Madison, AL
13 Dec 2012 20:43roy-b-boy-b wrote: I personally don't like the rattle from the allballs steering head bearings. I use them but I don't like the rattle. I guess when they are compressed they don't rattle. Roy
Mine don't rattle at all. What torque spec did you use when you installed them? Ed
