Modifying a KZ650 rear end
  • 650mod
  • 650mod's Avatar Topic Author
Re: Modifying a KZ650 rear end
22 Oct 2012 23:33
#555298
Mark- could you PM me with what you did with your gauges? Like how you ran the ninja speedo into your stock pod, if you had to make up a custom gauge cluster mount, etc. I want to try and keep my gauges if possible without having to switch over to an electronic unit.
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • 650mod
23 Oct 2012 00:20
#555310
Those are all GORGEOUS builds- a guy could get lost in all those threads for days on end! :woohoo:
78 kz 650 custom
  • Mark Wing
  • Mark Wing's Avatar
23 Oct 2012 11:54 - 23 Oct 2012 11:56
#555357
Hey Devin here's my build thread. It's not as radical as some of the others but it's a 650 with mono-shock and USD forks.
Mark
kzrider.com/forum/11-projects/90187-a-new-begining-new-pic
Yorba Linda Cal.
Last edit: 23 Oct 2012 11:56 by Mark Wing.
  • 650mod
23 Oct 2012 12:26
#555359
Thanks, Mark!
78 kz 650 custom
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Oct 2012 18:02 - 23 Oct 2012 19:38
#555418
650mod wrote: Mark- could you PM me with what you did with your gauges? Like how you ran the ninja speedo into your stock pod, if you had to make up a custom gauge cluster mount, etc. I want to try and keep my gauges if possible without having to switch over to an electronic unit.
since i used a zx9 which also uses a cable operated speedo. all i had to do was make the zx cable fit into the kz speedo. or make the kz cable fit into the zx speedo drive at the wheel. fortunately the cable itself was the same at booth ends for both bikes. what was dif was the threaded cap at the bottom. so i just took the 2 cables apart and switch the cap ends.
Here is a pic of my top tree. All I had to do was cut the gauge mounts off of the kz tree and have them welded to my zx tree.
Attachment 96zx9toptree003.jpg not found
here is another pic in my build thread.
kzrider.com/forum/11-projects/103381-76-...de?limit=20&start=80
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 23 Oct 2012 19:38 by mark1122.
  • 650mod
23 Oct 2012 19:59
#555435
Awesome! Thanks, Mark! :laugh:
78 kz 650 custom
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Oct 2012 22:21
#555470
At your service sir. :)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 650mod
23 Oct 2012 22:38
#555480
I have a set of forks off a 2001 Buell going onto the Kaw, so I'll have to do the same steering shaft modification. The forks I'm using have a triple tree from Accutronix, which are worth quite the big $. Luckily enough, I got the whole set up for a VERY good price ($150 for forks, front wheel, and triple trees).
I'm stuck between running my Superbike bars, or switching over to clips. Time will tell, I suppose.
Devin
78 kz 650 custom
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Oct 2012 23:23
#555508
650mod wrote: I have a set of forks off a 2001 Buell going onto the Kaw, so I'll have to do the same steering shaft modification. The forks I'm using have a triple tree from Accutronix, which are worth quite the big $. Luckily enough, I got the whole set up for a VERY good price ($150 for forks, front wheel, and triple trees).
Devin
u have to know by now that u cant just say u r doing this stuf without proof. who will beleive u??????
we need pics.
:laugh:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 650mod
23 Oct 2012 23:47
#555511
Haha I know, I know Mark! Pics will come as soon as I have the bike in the shop, all ready to go. I promise! I'll start a build thread and post on here as to what it is.
Devin
78 kz 650 custom
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Oct 2012 23:54
#555513
i dont beleive u.
lol
talk to u tomorrow. i'm out a here. :)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mike0537
  • mike0537's Avatar
24 Oct 2012 19:37
#555605
PICS!!!!
I love watching these things go! I am also in the middle of a build. I'll include my build thread if you are interested.
kzrider.com/forum/11-projects/547424-kz750e1-fighter-build
Hope you can find something usefull. More pics will be added soon. Once I get the sprockets/chain alignment issue solved I will remove the engine for sand blasting and paint.
1980 KZ750E
