Modifying a KZ650 rear end
  • 650mod
  • 650mod's Avatar Topic Author
Re: Modifying a KZ650 rear end
18 Oct 2012 14:54
#554513
Leon,
What had to get massaged on the rear end to make everything line up? Like you were suggesting earlier, I really don't mind if my front-rear wheels are offset a bit, as long as I can ride it.
Thanks,
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
18 Oct 2012 15:40 - 18 Oct 2012 15:51
#554520
devin,
the counter shaft sprocket is on the engine,those can be offset.you may or may not depending on what you use,have to machine the cush drive(which is what carries the rear sprocket).
i custom built my own swingarm(to house the wheel and brakes from a 2000 r1),offset counter shaft sprocket and run a 520 o-ring chain. :)
besides for that, :whistle:
it was a bolt up deal :silly: .
no frame mods tho.
i have long term plans of putting the 80 back stock and turning one of my other 1978 z1r's into what this one has become,kinda deal.
Last edit: 18 Oct 2012 15:51 by 531blackbanshee.
  • 650mod
18 Oct 2012 16:43
#554531
Leon,
I looked into the "countershaft" term last night and found out it's just the front drive sprocket- just hadn't heard the term before :P
I may do the cush drive offset to save my frame. The other thing I was thinking about it offsetting the swingarm slightly, but that's probably not the best idea for my frame. Either way, I'm sure a cush drive offset and sprocket offset will make my alignment happy :)
Thanks for the tips!
Devin
78 kz 650 custom
18 Oct 2012 19:13
#554547
Sprockets should be perfectly aligned with each other in the identical geometric plane.
The wheels should be aligned whereby both wheels point in the exact same direction.
However, it's not necessary that the center-line of the rear tire thread track over the center-line of the front tire thread.
Several new motorcycle models, especially those with fat rear tires, do not have tire center-lines in the same geometric plane.
Good Fortune! :)
  • 650mod
19 Oct 2012 21:42
#554767
Patton:
Thanks for the visual. I'll probably end up offsetting my wheel and running an offset sprocket up front to save my frame.
I just got all my parts in today- looks like I'll have some machining to do on the swingarm, but I'll be able to get things to work :) I'll start a build thread when everything is up and going.
Devin
78 kz 650 custom
  • Ederer
  • Ederer's Avatar
22 Oct 2012 16:19
#555204
Looking forward to seeing your progress.
I'm planning on something similar, hopefully starting in a few weeks.
  • 650mod
22 Oct 2012 21:33
#555270
Well, it's looking like the front end is going to get done this winter too. I have a set of forks and wheel off a 2001 Buell Lightning that I got for pretty cheap off a friend (and good machinist) that will be put on the bike. Only down side to this set up is that I can only run one disc up front as these bikes only ran a right side caliper (unless I make up an adapter that can house another right side caliper).
Once everything is underway, pictures and a build thread will be up.
Devin
78 kz 650 custom
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
22 Oct 2012 21:43 - 22 Oct 2012 22:44
#555273
dont be afraid to offset the swingarm too. anything goes with these builds.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 Oct 2012 22:44 by mark1122.
  • 650mod
22 Oct 2012 22:17
#555280
Hey Mark,
I'm thinking I may have to offset my swingarm as the rim holds quite the chunk of rubber :) I'm looking forward to the build of my "new" old Kaw. She'll be kind of a Frankenstein when it's all done :)
Devin
78 kz 650 custom
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
22 Oct 2012 22:47
#555285
Yes they do. u can run a 190 on that 5.5 rim. u just have to figure out how to squeeze everything in there. i have a feeling that u r the kind of guy that is good with a shoe horn though. lol
Good luck with the build and most of all , Have fun with it.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 650mod
22 Oct 2012 23:24
#555296
Haha I sure am :) I have two really skilled machinists working with me too, so fabbing parts/machining/shaving parts down will be no issue. Just a matter of "how will this work" and "what needs to happen next" in this case.
I absolutely will have fun with this one- I LOVE doing custom work like this :)
Devin
78 kz 650 custom
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
22 Oct 2012 23:26 - 22 Oct 2012 23:37
#555297
Can wait to see it all unfold. or should i say cut and weld. ;)
i'll see if i can post a few builds for u to look at as inspiration.
i'll be right back. lol
here u go.
kzrider.com/forum/11-projects/390747-1977-kz1000-new-life
kzrider.com/forum/11-projects/539557-76-kz900-zrx1200r-build
kzrider.com/forum/11-projects/454601-1980-project
kzrider.com/forum/11-projects/481447-78-...0-build-im-learnding
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 22 Oct 2012 23:37 by mark1122.
