Got my 530 conversion kit HAVE ? need help ASAP
  • KJ
  • KJ's Avatar Topic Author
26 Aug 2012 11:51
#544840
Got my 530 chain conversion JT Sprockets, The stock front sprocket has a hole in it for the safety lock washer to lock into. I tried to drill a hole in it but it is hardened so no luck. Should there be a hole or will I be safe just bending it over like it was.
  • wireman
  • wireman's Avatar
Re: Got my 530 conversion kit HAVE ? need help ASAP
26 Aug 2012 12:05
#544842
without a hole in the sprocket the washer/tab really does no good.
Put some red lock tite on the threads before torquing the nut down. B)
  • KJ
26 Aug 2012 14:31
#544859
Yea with out hole the saftey washer dose no good, I was woundering if I had the correct sprocket or just use some locktite.
  • wireman
  • wireman's Avatar
26 Aug 2012 14:38
#544862
Get everything all together on bike to make sure it lines up before cranking the nut down on there,that way you can use the brakes on bike to keep sprocket from turning while cranking it down.
Id check the nut again between 50-100 miles to make sure its tight B)
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
26 Aug 2012 15:13
#544865
I'd also suggest getting one of those very thin lock washers that are meant to have one (or more) sides bent up flat against a side of the nut. Personally speaking, I wouldn't trust locktite alone.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • mtbspeedfreak
26 Aug 2012 15:18
#544866
mtbspeedfreak wrote: I'd also suggest getting one of those very thin lock washers that are meant to have one (or more) sides bent up flat against a side of the nut. Personally speaking, I wouldn't trust locktite alone.
I also don't trust hipsters, hippies, and liberals, no discrimination against Loctite intended. :P
2000 ZRX 1100
  • wireman
  • wireman's Avatar
26 Aug 2012 15:21
#544868
If his sprocket doesnt have the hole to catch the tab on washer its not going to really do any good will it? B)
  • mtbspeedfreak
26 Aug 2012 15:31
#544871
wireman wrote: If his sprocket doesnt have the hole to catch the tab on washer its not going to really do any good will it? B)
Yep, a lock washer like this:
2000 ZRX 1100
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
26 Aug 2012 15:32
#544872
YA
WHAT HE SAID.
  • MFolks
  • MFolks's Avatar
27 Aug 2012 01:57
#544995
To put a hole in a hardened sprocket, find a local machine shop with a EDM(Electronic, Discharge Machining) hole popper. A Cobalt bit might be able to drill the hole, but EDM is quicker.
  • MFolks
  • MFolks's Avatar
27 Aug 2012 02:24
#544998
That should have read EDM(Electrical, Discharge Machining):
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
27 Aug 2012 12:02
#545039
if the "locking washer" has splines in the center then the edges are bent up,it will keep the nut from spinning.
if it does not have splines in the center it will not keep the nut from spinning with the edges bent up.
hth,
