Got my 530 conversion kit HAVE ? need help ASAP
- KJ
26 Aug 2012 11:51
Got my 530 chain conversion JT Sprockets, The stock front sprocket has a hole in it for the safety lock washer to lock into. I tried to drill a hole in it but it is hardened so no luck. Should there be a hole or will I be safe just bending it over like it was.
- wireman
Re: Got my 530 conversion kit HAVE ? need help ASAP
26 Aug 2012 12:05
without a hole in the sprocket the washer/tab really does no good.
Put some red lock tite on the threads before torquing the nut down.
- KJ
26 Aug 2012 14:31
Yea with out hole the saftey washer dose no good, I was woundering if I had the correct sprocket or just use some locktite.
- wireman
26 Aug 2012 14:38
Get everything all together on bike to make sure it lines up before cranking the nut down on there,that way you can use the brakes on bike to keep sprocket from turning while cranking it down.
Id check the nut again between 50-100 miles to make sure its tight
- mtbspeedfreak
26 Aug 2012 15:13
I'd also suggest getting one of those very thin lock washers that are meant to have one (or more) sides bent up flat against a side of the nut. Personally speaking, I wouldn't trust locktite alone.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
26 Aug 2012 15:18mtbspeedfreak wrote: I'd also suggest getting one of those very thin lock washers that are meant to have one (or more) sides bent up flat against a side of the nut. Personally speaking, I wouldn't trust locktite alone.
I also don't trust hipsters, hippies, and liberals, no discrimination against Loctite intended.
2000 ZRX 1100
- wireman
26 Aug 2012 15:21
If his sprocket doesnt have the hole to catch the tab on washer its not going to really do any good will it?
- mtbspeedfreak
26 Aug 2012 15:31wireman wrote: If his sprocket doesnt have the hole to catch the tab on washer its not going to really do any good will it?
Yep, a lock washer like this:
2000 ZRX 1100
- 4TheKZ1000
- MFolks
27 Aug 2012 01:57
To put a hole in a hardened sprocket, find a local machine shop with a EDM(Electronic, Discharge Machining) hole popper. A Cobalt bit might be able to drill the hole, but EDM is quicker.
- MFolks
27 Aug 2012 02:24
That should have read EDM(Electrical, Discharge Machining):
27 Aug 2012 12:02
if the "locking washer" has splines in the center then the edges are bent up,it will keep the nut from spinning.
if it does not have splines in the center it will not keep the nut from spinning with the edges bent up.
hth,
hth,
