Tarozzi rearsets? .02 anybody?
  • kamakazie1000
  • kamakazie1000's Avatar Topic Author
03 Jun 2012 23:41
#526687
Found these the other day, looks legit enough. Comments, concerns, .02?
www.fastfromthepast.com/servlet/the-100/...-Fixed-Rubber/Detail
Terminal lance corporal of Marines, putting the GRUNT in disgruntled
kz1000 cafe project
  • MFolks
  • MFolks's Avatar
Re: Tarozzi rearsets? .02 anybody?
04 Jun 2012 00:02
#526697
Good quality, I've sent many riders to this website for front fork braces and rear sets.
  • kamakazie1000
04 Jun 2012 00:12
#526701
cool man, i have a 77 kz1000 ltd. will they bolt on? also i got a little cut happy with the sawzall and cut the triangle things that come off the back of the frame off, like the things that the rear pegs and exhaust mount to. is that gonna be a problem?
Thanks,
J.H.C
Oorah devils
kz1000 cafe project
  • MFolks
  • MFolks's Avatar
04 Jun 2012 00:21
#526706
You should have them re-welded, as they are frame supports........
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
04 Jun 2012 00:28 - 04 Jun 2012 00:30
#526708
Yep, mine did. They are legendary. I've been planning to remove those rear peg mounts myself but I just haven't gotten to it. It shouldn't be a problem except now where do you hang the exhaust and where will your passenger put her feet? I am planning on putting removable stalks that move the passenger's feet back a bit and also so the hanger location actually matches the Kerker support point location. It's in the plan anyway.
Oh, wait, you have a B model. Nevermind. Different peg supports. Why would you want to put rearsets on an LTD?
Last edit: 04 Jun 2012 00:30 by DiamondSkyBlue1000. Reason: Didn't realize he had a B model.
  • wireman
  • wireman's Avatar
04 Jun 2012 00:29
#526709
kamakazie1000 wrote: cool man, i have a 77 kz1000 ltd. will they bolt on? also i got a little cut happy with the sawzall and cut the triangle things that come off the back of the frame off, like the things that the rear pegs and exhaust mount to. is that gonna be a problem?
Thanks,
J.H.C
Oorah devils
Only thing you need them for is the exhuast hanger on right side,stock brake pedal mount isnt needed anymore with the rear sets B)
  • kamakazie1000
04 Jun 2012 01:05
#526721
Well im going to have some bracing welded into the frame so im not really worried about loosing the minimal frame support they offered.
Im putting rearsets on an ltd because im making it a cafe, durrrr.
As far as passengers, thats what my truck is for. If my girlfriend wants to ride on a bike, she can go build her one, im building this one, its mine to ride.
Also, please dont tell my girlfriend i said that...
kz1000 cafe project
04 Jun 2012 02:01
#526729
Well, that make sense. It just seemed odd to put rearsets on a cruiser.
Best of luck with your project!
  • StreetfighterKz
  • StreetfighterKz's Avatar
04 Jun 2012 08:37 - 04 Jun 2012 08:37
#526745
wireman wrote: stock brake pedal mount isn't needed anymore with the rear sets
You'll need it with the Tarozzi's. They use a linkage system that utilizes the stock brake pedal mount.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 04 Jun 2012 08:37 by StreetfighterKz.
  • wireman
  • wireman's Avatar
04 Jun 2012 10:18
#526754
Later, Doug
ah,did not know that.
I guess im used to seeing all you guys with sportbike rear sets B)
  • kamakazie1000
04 Jun 2012 13:00
#526785
Looks like i'll be putting that engineering degree to work. Let the fabricating begin!!!
kz1000 cafe project
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
04 Jun 2012 15:49
#526836
I think someone with them installed should post some pics. I'm interested in them as well. Keep dragging my shoes around corners...
2000 ZRX 1100
1976 KZ 900- Daily Driver
