What front end did you use?
  • ramtough_63
  • ramtough_63's Avatar Topic Author
12 Feb 2012 12:18
#503471
Is seems there are alot of guys who've made the front end swaps
I think it would be a good idea to post pic's and technical info on what front end you used and any speedo,handlebar, tire size brakes and any info you can help those of us who plan on making the swap
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • Boostable
  • Boostable's Avatar
Re: What front end did you use?
12 Feb 2012 17:35
#503511
Ram, What you thinking about doing?
In my case I went with a ZX10R front end. The issue in most cases is the different in ride height and how you are willing to cope or compensate for the difference. I think you can pretty much use any front end (with in reason) but some are a litter longer then others.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • M357.5
  • M357.5's Avatar
  • Kwakas N' lots of em'
12 Feb 2012 17:50 - 12 Feb 2012 17:51
#503518
- 2005 ZX6R forks
- 2005 ZX6R lower triple
- Custom machined stem, uses stock KZ bearings
- HoHey ZX6R stunt top triple, it is a dropped design meant for use with clipons above the triple instead of under...slide the tubes down flush with the top of it and you gain 1-1.5" in fork length. It is also drilled for risers
- Driven 1 1/8th bar risers
- Driven Carbon Fibre 1 1/8th bars, CR high bend
I went with spoked wheels, Behr Supermoto 17x3.5 rim, Ducati Sport Classis hub, Ducati spokes, custom disk spacers, Wave rotors, custom wheel spacers, custom caliper spacers ( stock disks were 300mm on the ZX6R, the Ducati rotors are 320mm )
Any questions about my setup just ask :)
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Last edit: 12 Feb 2012 17:51 by M357.5.
  • ramtough_63
12 Feb 2012 17:56
#503521
Boostable wrote: Ram, What you thinking about doing?
I'm looking to go ZX front end It sounds silly but I want to stay Kawasaki
I need to find a deal on one as my swingarm mod comes to a close I want to start collecting parts
and resally want to see some different front ends and ideas people have used. also help anyone else that is contmplating the swap
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
12 Feb 2012 17:58
#503523
M357.5 wrote: - 2005 ZX6R forks
appreciate the post if you have any pic's of the front angle of your bike I'd appreciate seeing it
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • M357.5
  • M357.5's Avatar
12 Feb 2012 18:13 - 12 Feb 2012 18:16
#503528
Its all in my build thread :)
Oh I happen to have a 2006 ZX6R complete front end for sale too. Have an 03-04 front wheel and rotors and more stuff too if your looking.
Her is a pic of my setup. Also running a Carbon Fiber front fender but not in the pic's.
Last edit: 12 Feb 2012 18:16 by M357.5.
The following user(s) said Thank You: ramtough_63
  • ramtough_63
12 Feb 2012 18:17
#503529
M357.5 wrote: Its all in my build thread :)
It's probably out of my price range at the moment but pm a price it is almost valentines day lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
12 Feb 2012 18:20
#503530
love the spokes! nice look!
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • M357.5
  • M357.5's Avatar
12 Feb 2012 18:29
#503535
Thank you, I kinda dig it myself :)
PM'd on the forks/wheel
  • Boostable
12 Feb 2012 23:08
#503619
More info for the cause..
The 04-05 ZX-10R forks are 730mm, the 06-07 are 743mm
~Jack
  • 893cv
  • 893cv's Avatar
13 Feb 2012 00:10
#503638
Attachment IMAG0033_2012-02-12.jpg not found
Attachment IMAG0009_2012-02-12.jpg not found
I am using forks from a 2000 YZF600r on my 1980 KZ1000 LTD project. These forks are 806mm long (31 3/4in.). It's axle is 17mm, same as the stock KZ1000 axle, so I will be using a stock KZ1000 wheel to start. Eventuly I will use a stock hub and build a wideer spoke wheel. I also made this triple clamp with 60mm of offset (stock offset for my bike is 63mm). I have used these forks on several projects because there are lots of aftermarket tuining parts for them. Race Tech sells compression and rebound gold valves, propper rate springs, bushings, and seals to set them up correctly for the KZ1000 weight.
1980 kz1000 LTD
1978 Z1R
The following user(s) said Thank You: ramtough_63, bluezbike
  • jydog
  • jydog's Avatar
13 Feb 2012 11:12
#503705
05-06 636 with 81 kz1000 pressed in stem and bearings.
05-06 636 lower and z1000 upper with trx450 fatbars.
81 KZ1000 LTD
Griffin GA
