What front end did you use?
- bluezbike
Re: What front end did you use?
08 Mar 2012 17:39
Thanks M357.5,
I did see that rather nice looking triple tree of porche's, as far as I can see it gives you at most an inch and a half, that might be enough. I still want to find out if the forks can be stretched, the sliders are 46 mm. diameter and that's a tough size to find.
Bluezbike
Bluezbike
79 KZ 1000 LTD
- mark1122
- Keep twisting it
08 Mar 2012 18:39 - 08 Mar 2012 18:44
there r companies out there that make lonbger fork tubes. i think Leon posted a link once. try a google search.
heres a start
about $200 +
www.ccesd.us/index.php?main_page=index&cPath=128_129
heres a start
about $200 +
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 08 Mar 2012 18:44 by mark1122.
08 Mar 2012 19:13
- bluezbike
08 Mar 2012 21:49
Thank you guys, I tried Frank's this morning but he does not deal with anything over 43 mm. diameter, I will try Mark's link and google
79 KZ 1000 LTD
- gengomerpyle
08 Mar 2012 21:59
nice looking bike.
mark1122 wrote: fork length was behind my choice.
Attachment forks.jpg not found
96 zx9 front end just swapped the stems.zx9 uses a cable drive like the kz.i cut the kz top tree gauge mounts off and welded them onto the zx9 top mount and used the kz gauges.
Attachment _rt_side.jpg not found
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- M357.5
- Kwakas N' lots of em'
12 Mar 2012 13:24 - 12 Mar 2012 13:25
Hey guys, all this talk about ride hight had me wondering. I did alot of research in my components to give me the proper ride hight, but had not had my project loaded to see where it was going to sit once ready to ride.
So i grabbed a bunch of my free weights and set 250lbs into the frame to simulate the engine and remaining components such as battery etc.
I happen to have my daily rider KZ750L4 sitting beside the project
so stood it up and measured to the crashbar mounting tab on the frame = 8.5"
Then i measured the project bike in the exact same spot = 8.75"
So I gained a 1/4" in ride hight even with 28.250" long ZX6R forks and a 17" wheel, instead of the stock 30.250" long forks and the 19" front wheel.
My point is, with careful planning you dont need to worry about ride hight. Just dont throw a set of stock modern triples/forks on it and expect to have a decent ride hight.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
Last edit: 12 Mar 2012 13:25 by M357.5.
- mark1122
- Keep twisting it
12 Mar 2012 13:53 - 12 Mar 2012 13:55M357.5 wrote: So I gained a 1/4" in ride hight even with 28.250" long ZX6R forks and a 17" wheel, instead of the stock 30.250" long forks and the 19" front wheel.
quote]
so u lost 2" from the forks and 2 1/4" with the wheel. so what did u change to gain that back, plus 1/4" "
how much did u gain with the drop tripple tree ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 12 Mar 2012 13:55 by mark1122.
- M357.5
12 Mar 2012 13:58
Drop top triple clamp gained back over 2.5", decreased rake to 24.5* from the stock 28* which stood the forks up. Also the offset decreased too which shortened the wheelbase, along with raised rear ride hight.
- mark1122
- Keep twisting it
12 Mar 2012 17:26
wow thats quite a big drop. thats good to know. i had thought they were about a 1" drop.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- M357.5
12 Mar 2012 18:00 - 12 Mar 2012 18:07
Unloaded mine sits at 9.5" at the crashbar bracket. And at the back where it starts to bend upwards for the swingarm pivot it is 9.75".
I lose .5" at the front and .625 rear when loaded.
Stock is 8.5" and 9.250" loaded
but thats with the longer Zephyr rear shocks on it.....it use to sit almost level at 8.5" front and 8.75" rear with stock shocks.
Swingarm sits at 7* on my stock bike with Zephyr shocks.
Swingarm sits at 10* on my project bike, swingarm is 1" longer than stock and the eccentrics are set for more ride hight ( axel at the bottom ) This compensated for the shorter 17" rear I'm uning instead of the stock 18" wheel.
Last edit: 12 Mar 2012 18:07 by M357.5.
- bluezbike
13 Mar 2012 03:27
I am wondering if the modern forks compress less than the originals which would also help. I think Leon posted a warning in another thread about the risks of messing with the ride height/rake and trail when swapping forks and then riding hard without doing some homework and calculations beforehand, got me worried.
Bluezbike
Bluezbike
79 KZ 1000 LTD
14 Mar 2012 13:02
i don't know how much the modern front ends dive compared to the older ones.
you definately don't want to hit your front brakes and have the front end dive and your front tire to contact the header and wedge,or lock the tire :sick: .
