KZ1000 steering damper mounting
- rstnick
Re: KZ1000 steering damper mounting
09 Jun 2012 14:29 - 09 Jun 2012 14:47
Just got a steering dampener in a parts swap with a fellow 650 owner.
It came with a front clamp for the fork tube, but the frame mount on the dampener is too large for the reflector mount hole.
I will make a bracket to accept the larger size, or drill & tap the reflector mount.
I'm not having any issues with wobbles or anything.
Had thought of using a dampener for some time, and now have the chance for next to nothing.
Have it mounted,using the reflector tab on the frame which is quite solid on the 650 frame, and have taken some rides.
I had some mounting issues, adjusting the mounts a few times to make clearance on both left & right turns.
The fairing ended up getting in the way on full right turns, dampener mounted on the right.
I moved the fairing out an inch on that side.
Still need to get used to the dampener while riding, but have not really noticed it, which is a good thing.
It has 6 clicks, to tighten the steering, and have clicked it up to 3 & 4 on some 80 kph+ riding.
Nice to know it's there when hitting cracks and road snakes in the road.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 09 Jun 2012 14:47 by rstnick.
