KZ1000 steering damper mounting
- Kapahulu
03 May 2011 15:08 - 03 May 2011 15:10
I'm looking for steering dampers for my KZ1000. There are plenty of dampers on the market, mounting them seems to be the tricky part.
So far the most straightforward system I've found is on Redline's website here: www.redlinecycle.com/Steering%20Damper.html
Anybody have other ideas or favorite dampers and mounting systems?
My KZ gets a little headshake under acceleration sometimes and I want to keep it under control.
Thanks, Mike
Thanks, Mike
2strokeworld.com
2strokeworld.com
Last edit: 03 May 2011 15:10 by Kapahulu.
- mark1122
- Keep twisting it
Re: KZ1000 steering damper mounting
03 May 2011 16:51
if u get head shake u should cure it before adding a damper. these bikes dont need dampers for the street. if u have headshake u have a problem. check the steeringhead bearings, swingarm bushings and tire balance first. i can take my 1200cc kz to the track and have no shake.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- MFolks
03 May 2011 17:10
Tire pressure,front fork hardware tightness can also affect head shake at speed.
- Kapahulu
03 May 2011 19:11 - 03 May 2011 19:12
Thanks for the tips. I am going to change out the 16" mag on the rear for an 18" spoke wheel someday when I have time. I already have the wheel, just need to take it apart, clean and coat it, install the stainless spokes, etc.
When I'm working on that I can check the swingarm bushings and head bearings.
BTW the head shake is not very bad. Just a little wobble sometimes when accelerating hard. Tire pressure is 30-35 lbs each.
2strokeworld.com
2strokeworld.com
Last edit: 03 May 2011 19:12 by Kapahulu.
- donthekawguy
04 May 2011 03:46
I got my dampner from schnitz about 7 years ago and still havent put it on. Maybe I'll get on it someday. lol
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- zmaniscalco
04 May 2011 10:28
any shakes over 100mph can get scary quick
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
- z1kzonly
04 May 2011 12:34mark1122 wrote: if u get head shake u should cure it before adding a damper. these bikes dont need dampers for the street. if u have headshake u have a problem. check the steeringhead bearings, swingarm bushings and tire balance first. i can take my 1200cc kz to the track
Hi Mark, off topic, love the paint in your avatar!
Got any more pictures of it complete?
Is that a candy red? with marblizing on the sides?
Thanks.
Marty
- zmaniscalco
29 Aug 2011 13:58
To start I have a lowered bike.
I had no problem till I changed struts to shocks and changed steering head bearings. It has new swing arm bearings, and I get a weave in my tail at high speeds.
I am going to add a steering damper and on a 79 kz1000 frame I do not see a good place to mount I am looking for ideas. I am thinking of top of valve cover with a custom mount, or a mount that will have to drill the frame. Help.
[attachment:1]C:\fakepath\bike.jpg[/attachment]
[attachment:2]C:\fakepath\(1002 of 1).jpg[/attachment]
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
- zmaniscalco
29 Aug 2011 14:05
Attachment bikeweb.jpg not found
Attachment bikeweb2.jpg not found
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
- T_Dub
29 Aug 2011 14:10
Look at the link he posted in his original post, mounts right up to your bike.
Kickass bike!
Kickass bike!
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- zmaniscalco
29 Aug 2011 14:17
I cannot find the NHK mount for the valve cover? And the top damper in the link mounts to a z model that had a reflector.
Thanks it is a blast to ride.
78 kZ1000
79 KZ1000 Ltd turbo
79 KZ1000 Ltd turbo
- T_Dub
29 Aug 2011 14:30
Oh I thought I saw a reflector mount on yours. I just figured they all have it since the Z1 has it and my 650 also does.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
