TIRES: Going Tubeless
Re: TIRES: Going Tubeless
03 May 2011 10:13 - 03 May 2011 10:14
#448521
Correct! The '77 KZ650-C1 rear wheel does require 2 bead locks (also known as rim locks). Ed
Attachment rimlock0001.jpg not found
Last edit: 03 May 2011 10:14 by 650ed.
  • testarossa
  • testarossa's Avatar
03 May 2011 10:53
#448531
Somehow, I doubt the tire is holding air if the wheel is made for rim locks and they are not present.
I second martin_csr's advice to take the wheel back to the installer to at least verify the correct installation. You paid a professional to mount the tire, and they need to make it right.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Omaha Rider
  • Omaha Rider's Avatar
03 May 2011 20:07
#448631
Ok, I talked to one of the guys at a shop and he said that if the rims say TL on them, then they are tubeless. But here I see a T in front of everyhing else aswell as a TL. I am confused. Are they tubeless or tubed?
1978 KZ650 SR D
  • MuzzleMike
  • MuzzleMike's Avatar
  • Rice Only
07 May 2011 01:05
#449368
I read the thread just last night and I changed my front tire today . It is a 1982 KZ750 LTD with tubeless rims and tires on it and guess what I found ? The same thing that mjg15 found on his and it has the same numbers his has . I higher it has help up for 29 years and it should be ok but it still bothers me a little .
Mike
82 KZ750 LTD H3
07 May 2011 13:18
#449430
The 1982 KZ750 LTD drawing for tires on Kawasaki.com shows no inner tubes. If you look at earlier drawings (like 1979 and 1 of the 1980 KZ750 models) they do show tubes. Assuming your bike has stock wheels, I believe the owners manual and Kawasaki service manuals give the specs for tube or tubeless if you want to double check. Ed
  • MuzzleMike
  • Rice Only
07 May 2011 16:09
#449445
I check my manuals and it is tubeless .
Mike
82 KZ750 LTD H3
