TIRES: Going Tubeless
  • HolyKAW
  • HolyKAW's Avatar Topic Author
01 May 2011 23:23
#448184
My kz650 is in painful need of a new rear tire, but the one that is on it has an inner tube (yuck). How easy is it to convert to a tubeless setup? Can i just buy a tubeless tire and pump it full of SLIME or Stan's? Do i use the valve from the old inner tube somehow?
1977 KZ650C1
1977 KZ650B
1992 ZG1200, Kawasaki Voyager XII
Son, you just don't understand, it ain't the car I want- it's the brunette in your 'vette that turns me on!!
  • testarossa
  • testarossa's Avatar
Re: TIRES: Going Tubeless
01 May 2011 23:27
#448185
You absolutely cannot go tubless unless your wheel is specifically designed for tubless tires. Tubeless wheels have a lip that holds the bead in place that will not be present on a tube type rim. IIRC all tubless rims will have the word "tubless" cast, stamped etc somewhere on the rim to eliminate confusion.
Please do not attempt to convert a tube type wheel for a tubeless tire. You must get a tubeless wheel to make the conversion.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • dblhdr
  • dblhdr's Avatar
01 May 2011 23:36
#448190
First take a look at your rims and verify that they are stamped "TUBELESS" on them. This is probably somewhere along one of the spokes on mag wheels or along the edge of the rim. If they are marked rimless then just take them to the dealer and have them mount the tire of your choice. They will add a new valve stem on to the rim where the innertube valve was sticking out. Or you can get your own valve stem and fight the tire on yourself. Personally I let the dealer do it, If your rims are not marked tubeless, then you need an inner tube with those rims even if the tires are tubless tires.
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
02 May 2011 00:40
#448203
Do yourself and your wallet a HUGE favor and read both pages of the following KZR posting. Pay special attention to the photos on the second page.
kzrider.com/forum/13-bike-related/442786...-while-riding#442786
  • mjg15
  • mjg15's Avatar
02 May 2011 00:47
#448205
My 81 550 has "tubeless" cast into both rims, but the front doesnt have the extra lip. Is that common among other Kaws? I noticed the lack of the inner lip after dismounting the old tires, so I checked for the letters in the casting and both of them had it.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • testarossa
02 May 2011 01:30
#448209
mjg15 wrote: My 81 550 has "tubeless" cast into both rims, but the front doesnt have the extra lip. Is that common among other Kaws? I noticed the lack of the inner lip after dismounting the old tires, so I checked for the letters in the casting and both of them had it.
Got a picture of the inside of your rims?
2004 ZX-10R
Angola, IN
  • martin_csr
  • martin_csr's Avatar
Re: -
02 May 2011 08:59 - 13 Feb 2013 13:12
#448229
Last edit: 13 Feb 2013 13:12 by martin_csr.
  • mjg15
  • mjg15's Avatar
02 May 2011 10:16
#448241
I put tires back on, but I'm pretty sure that the front had no extra lip, which surprised me and prompted me to check for the "tubeless" lettering in the casting. I think that I have a spare wheel kicking around the garage, I'll take a look later and see if it's the same.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
02 May 2011 11:10
#448248
:) Pic for reference:
Attachment tubevtubelessrimtxt.JPG not found
  • martin_csr
Re: -
02 May 2011 12:32 - 13 Feb 2013 13:12
#448258
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
02 May 2011 14:36
#448288
Same with mine. The older castings tend to seep so you have to keep your eyes on the tire pressure every once in awhile if not :unsure: not a good idea.
79 LTD B3
  • mjg15
  • mjg15's Avatar
02 May 2011 17:30 - 02 May 2011 17:33
#448332
Heres the pics of an '81 GPz550 front wheel with no "tubeless" ridges. Maybe the angle of the bead seat area is different than the tube-type rims? I have a tube-type Z1R front wheel somewhere, when I get a chance I'll compare them.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 02 May 2011 17:33 by mjg15.
