HELP with Extended Swing Arm
  • PLUMMEN
  • PLUMMEN's Avatar
Re: HELP with Extended Swing Arm
18 Feb 2011 06:04
#431491
i wonder if you have a weak/blown shock on one side? B)
  • bmannon
  • bmannon's Avatar Topic Author
18 Feb 2011 06:16
#431496
I'm leaning towards the right side just being off a little from the factory as nothing appears bent or twisted. If that isn't the case then possibly someone used the right ride mount as a lifting point and it got tweaked in the process. I am taking it to a local that has a long history with these bikes and have him look at it and will let everyone know what I find out. Be a few days.
  • PLUMMEN
  • PLUMMEN's Avatar
18 Feb 2011 06:22
#431498
try swapping the shocks side to side and see what it does ,if frame was bent sitting on it isnt going to change that.
  • bmannon
18 Feb 2011 06:31
#431503
wouldn't that mean the arm is twisting? i can't see that happening.
  • PLUMMEN
  • PLUMMEN's Avatar
18 Feb 2011 06:50
#431504
the shocks play a big part of tying everything together,when bike is on sidestand the weight is shifted a bad shock would magnify the affect.
if id known about it leveling out when you sit on it i would of suggested checking shocks earlier :laugh:
  • bmannon
18 Feb 2011 06:57
#431509
well i wouldn't say it levels out, the space just increases on both sides. i will swap them out though and see what happens, it's EZ enuff, kind of hope it isn't the shocks, they are Ohlins and I really can't afford to replace them.
  • PLUMMEN
  • PLUMMEN's Avatar
18 Feb 2011 06:59
#431511
some shocks are rebuildable B)
  • lewisj
  • lewisj's Avatar
18 Feb 2011 07:55
#431524
With the bike sitting straight up, can you measure your exhaust mounts from the groud to see if one has been tweaked? Check the swing arm heights as well for twisting. Beautiful Bike, good luck.
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
  • bmannon
18 Feb 2011 07:58
#431525
what is a good way to make sure it's level? i had a friend hold it upright last night to do this, but just a small tilt either way slews the measurements.
18 Feb 2011 08:12
#431526
:unsure: Perhaps shorter rear shocks might afford vertical clearance, as with the oem swing arm.
Good Fortune! :)
  • bmannon
18 Feb 2011 08:21
#431528
Good Fortune! :)
Or eliminating the pesky exhaust mount that seems to be the problem B)
18 Feb 2011 08:43
#431530
Here, for reference, is pic showing clearance on stock KZ900-B1 LTD (thinking same as standard model KZ900) with stock length shocks.
Good Fortune! :)
[Click on image to enlarge view.]
