HELP with Extended Swing Arm
- bmannon
17 Feb 2011 17:43
I just bought a '76 KZ900 that has a GS swing arm on it. The arm is hitting the frame on the RH side where the original pipes used to bolt up. On the LH side there is about 3/4" of clearance. I am kind of confused as to why this is happening. Can anyone shed some light onto why this may be happening?
- bmannon
- bmannon
- bmannon
- PLUMMEN
Re: HELP with Extended Swing Arm
17 Feb 2011 17:49
is it twisted?
i know you have to grind/clearance those brackets on some frames to clear the suzuki arms while others dont.
i used a porta power to push mine out on my ltd last time it was apart.
- PLUMMEN
17 Feb 2011 17:51
- bmannon
17 Feb 2011 17:52
It doesn't appear twisted but that was my first thought as well, it rides straight, but something is going on.
- PLUMMEN
17 Feb 2011 17:53
they should be the same on either side
- bmannon
17 Feb 2011 17:59
maybe the bracket is just pushed up on that side
- gane
17 Feb 2011 18:04
B, I would look to the Pivot bolt spacing if you haven't already. ( I installed a GSX1100 S/A in my KZ1000A1 @ 2 weeks ago ) A @ 4mm spacer on either side centered both pass. peg mounts & the drop at shock mounts,, Luck G
[img][/img] 1977 KZ1000A1
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
17 Feb 2011 18:14
sick wheels and bike, wish i had advice for ya....Joe
- bmannon
17 Feb 2011 18:15
gane, the centering looks good, its the vertical clearance on each side that is different.
