HELP with Extended Swing Arm
- bmannon
Re: HELP with Extended Swing Arm
17 Feb 2011 18:17
thanks for the compliments joe and jefferson. i bought it off another member, cant recall his user name right now. it's a nice bike, just need to figure out this little issue.
- Old Man Rock
18 Feb 2011 01:41 - 18 Feb 2011 03:08
First thought would be arm is not ideally centered...
Translation: To get the chain to align, they offset the arm/rim versus centering and modifying other components for ideal/preferred arm & rim alignments.
On each side of the pivot tube to inside frame, measurements equal?
Check your rear rim (center) to frame for alignments... You'll probably be surprised find your off centered 1/2" - 3/4".
It would be hard to see with the naked eye.... Larry C used a laser, good idea....
Or as Plumi mentioned, if the rim is truly centered, just grind off the inside of the point of contact on the exhaust mount...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 18 Feb 2011 03:08 by Old Man Rock.
- z1kzonly
18 Feb 2011 04:40
bmannon wrote:
Very Nice! Classy, Old School! My kind a bike!
Looks like a little tweakin with a porta-power or sludge hammer and a block of 2x4 can't fix.
Did the bracket leg get bent in transit, shipping somehow?
A ratchet strap, tie down has a lot of power.
Would ya' mind putting a $$ value on that motorcycle??
I am building one similar to sell.
Thanks.
Marty in Buffalo.
Thanks.
Marty in Buffalo.
- PLUMMEN
18 Feb 2011 05:35
Old Man Rock wrote:
it looks like his issue is under swingarm like something is twisted,not side to side from his pictures anywayFirst thought would be arm is not ideally centered...
- bmannon
18 Feb 2011 05:47 - 18 Feb 2011 10:47
yes exactly, the arm is centered, it is a an issue with the vertical clearance between the bottom of the arm and the top of the original exhaust mounts.
Last edit: 18 Feb 2011 10:47 by bmannon.
- Old Man Rock
18 Feb 2011 05:51
Hard to say in the photo's provided... 3/4" on the left but no mention of the right side measurement... That's why I askked...
Based on stable ride, with a twist that far to the right you'd think this would be all over the road....
Wonder if as mentioned, the exhaust mount arm was bent for the exhaust to fit on this frame....
I'd still be insuring the rim is centered... 1/2" is a considerable shift...
Ah well, possibly some others that have gone the GS route will chime in as well....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
18 Feb 2011 05:54
is there any way you could get the bike up on a center stand or something to get the frame level,then run a level through rear wheel and lay it on both sides of swingarm to compare notes?
thats the easiest way i can think of to check for straightness/square between frame/swingarm
- bmannon
18 Feb 2011 05:55
when it's sitting with no one on it the right side touches the top of the arm and there is approx 3/4" clearance on the other side. With a rider, there is clearance on both sides.
- PLUMMEN
18 Feb 2011 05:57
bmannon wrote:
have you checked the adjustment on your shocks?when it's sitting with no one on it the right side touches the top of the arm and there is approx 3/4" clearance on the other side. With a rider, there is clearance on both sides.
- Old Man Rock
18 Feb 2011 05:59
One thing that just came to mind...
Left side spacer isn't GS OEM...
Example, foudn the arm on E-bay, no hardware included.
Not sure what spacer so uses what they have....
Chain doesn't line up, too far left...
So instead of modifying spacer length, shift the whole arm right.... :blink:
Just thinking out loud here for a moment.... :S most likely I'm wrong.... Yeah, Like that'd be a first.... :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bmannon
18 Feb 2011 06:01
PLUMMEN wrote:
yes i did, they are both on the lowest setting.
bmannon wrote:have you checked the adjustment on your shocks?when it's sitting with no one on it the right side touches the top of the arm and there is approx 3/4" clearance on the other side. With a rider, there is clearance on both sides.
18 Feb 2011 06:04
measurements from the swingarm pivot should help determine how far off from each other they are.
but,these frames are not exactly known to be the most accurately jigged and aligned,it could just be that they just welded em on crooked at the factory.
