HELP with Extended Swing Arm
  • bmannon
  • bmannon's Avatar Topic Author
17 Feb 2011 17:43
#431365
I just bought a '76 KZ900 that has a GS swing arm on it. The arm is hitting the frame on the RH side where the original pipes used to bolt up. On the LH side there is about 3/4" of clearance. I am kind of confused as to why this is happening. Can anyone shed some light onto why this may be happening?
  • bmannon
Re: HELP with Extended Swing Arm
17 Feb 2011 17:44
#431367
Right side
  • bmannon
17 Feb 2011 17:44
#431368
Left Side
  • bmannon
17 Feb 2011 17:46
#431369
The bike in question...
  • PLUMMEN
  • PLUMMEN's Avatar
17 Feb 2011 17:49
#431370
is it twisted?
i know you have to grind/clearance those brackets on some frames to clear the suzuki arms while others dont.
i used a porta power to push mine out on my ltd last time it was apart. B)
  • PLUMMEN
  • PLUMMEN's Avatar
17 Feb 2011 17:51
#431372
nice bike! B)
  • bmannon
17 Feb 2011 17:52
#431374
It doesn't appear twisted but that was my first thought as well, it rides straight, but something is going on.
  • PLUMMEN
  • PLUMMEN's Avatar
17 Feb 2011 17:53
#431375
they should be the same on either side B)
  • bmannon
17 Feb 2011 17:59
#431378
maybe the bracket is just pushed up on that side :unsure:
  • gane
  • gane's Avatar
17 Feb 2011 18:04
#431379
B, I would look to the Pivot bolt spacing if you haven't already. ( I installed a GSX1100 S/A in my KZ1000A1 @ 2 weeks ago ) A @ 4mm spacer on either side centered both pass. peg mounts & the drop at shock mounts,, Luck G
[img][/img] 1977 KZ1000A1
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
17 Feb 2011 18:14
#431383
sick wheels and bike, wish i had advice for ya....Joe
  • bmannon
17 Feb 2011 18:15
#431385
gane, the centering looks good, its the vertical clearance on each side that is different.
