Mags on a 73 z1?
- Buckeye73z1
Mags on a 73 z1?
24 Jan 2011 10:42
Does anyone know if there is a simple "swap" from my stock wires (mine are crusty and the bike isn't stock anyway, so no "originality" worries here) to mags? I like my 19" front and 16" rear(original hub laced to 16" rim), but most of what I see has a disc set up for the rear and twin discs up front. I may eventually go that route, but for now just want something that will swap in easily. I noticed the early 80's KZ 550s came with drum rears, as did some of the KZ400/440/454s. Would those be a direct swap? I am running a single front disc and rear drum currently and don't want to convert the rear to disc or the front to dual disc yet (tight budget). Anyone had this issue before? My bike is a '73 Z1-900 running a stock hub laced to a 16" rim rear with drum brake and a 19" rim laced to a '76 KZ900 (4 bolt) hub and single disc currently.
1973 Z1 900 cutom-current
1975 KZ 400D cafe racer-sold
1981 Honda CB750c rat bike-sold
2000 ZX12-R-sold when first child born
- Mcdroid
- Gone Kwackers
Re: Mags on a 73 z1?
24 Jan 2011 10:54
Watch eBay and you'll eventually see a set of Lester mags for sale. Some were designed for the early Z1 series and had 19" fronts, 18" rear and were set up for a rear drum brake. They can be pricey at times, but at other times, reasonably priced...depending upon how many bidders there are.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- stonemaster
24 Jan 2011 10:57
dude i researched it long and hard, I dont remember which but a 750 twin had rear drumand was the only that would I dont remember the year I think 79 or 80 and good luck finding one, I finally just did the conversion to disc brakes, I can find out later today
- steell
24 Jan 2011 11:03
16" rear drum with 19" single disk front mag wheels?
No problem, 1980 KZ750G, axle sizes are the same.
That's assuming that your 900 has the same diameter rear axle as the 77-80 KZ1000. That's 20mm.
I think I have a set.
Bummer, I see I type to slow
Optional dealer installed Morris mag wheel kit for the 79 KZ750 would work also, but they are pretty rare.
- stonemaster
- steell
- Buckeye73z1
24 Jan 2011 11:28
I would LOVE a set of Lesters. The only problem is that the set I found on Ebay last week drew over $800 for the set and they were kind rough. Needless to say, at that price for that condition, it doesn't seem a viable option for me. If anyone has a set of those 750 rims for sale, PM me. I'd be VERY interested in buying them. Thanks for all your help, guys!
- stonemaster
24 Jan 2011 12:42
I'm not sure but u may want to check the brake drum diameter, Im not sure those are the same, looks to be a different diameter so u might wanna check on/buy that too
- mjg15
24 Jan 2011 15:16 - 24 Jan 2011 15:17
'80-83 KZ550's had drum rear and single disc front. Standard "A model" 550 had 19Fr/18Rr and LTD "C model" had 19Fr/16Rr. If they arent a direct bolt-on I'm sure that they are very close to it. There should be plenty on ebay. Later LTD550's had shaft drive, so beware of that.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 24 Jan 2011 15:17 by mjg15.
24 Jan 2011 15:48
LTD 750 (twin) had single disc front and drum rear into the mid-1980s. They were 19 & 16 inch diameter. I'm not sure if they will fit, but might be worth looking into.
- steell
24 Jan 2011 17:23
TexasKZ wrote:
The only one with mags and rear drum is the 1980 KZ750G as pictured above, 82-83 (84 in Canada) had spoke wheels with rear drum, and different axle sizes. 80 is the only 750 twin with drum rear that's a bolt on.
