Fork tubes
  • andy9802gt
  • andy9802gt's Avatar Topic Author
  • If it tastes that good, eat it yourself.
Fork tubes
19 Jan 2011 15:20
#423606
I've been looking for new fork tubes for my '78 LTD and all I can find are Z1 tubes which are 3/8" longer than mine or H1/H2 tubes and those are like 1" shorter. If I go with one or the other which it appears I'll have to, will the late model fork caps I have fit and can I reuse my springs and damper out of mine?
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • MFolks
  • MFolks's Avatar
Re: Fork tubes
19 Jan 2011 15:49
#423623
If you can't find what you need, this guy can make them for you:http://www.frankmain.qpg.com/
  • JMKZHI
  • JMKZHI's Avatar
Re: Fork tubes
19 Jan 2011 16:19
#423632
Have you tried ebbaayy? I don't know anything about your bike, but a simple KZ1000 fork search yielded some items.
KAWASAKI Z1/Z-1/KZ900/KZ1000 FRONT FORK TUBE SET-TUBES
1978 Kawasaki KZ1000 KZ 1000 LTD Front Forks Shocks
  • andy9802gt
Re: Fork tubes
19 Jan 2011 16:38
#423637
Yeah I tried fleabay. My problem with mine is they have some pitting in between the trees, I could rotate them to hide it but, I would know it was there and that alone would drive me nuts. I want to buy new just to be sure I don't get something that is in the same or worse condition than what I already have.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
Re: Fork tubes
19 Jan 2011 17:50
#423650
Did you look at Bike bandit, they dont call em bandit for nothing though lol
1979 kz 1000 06 katana 750
  • andy9802gt
Re: Fork tubes
19 Jan 2011 18:14
#423661
yeah lemo I looked, and for that price they can turn them sideways and shove them up their turd cutter. I may just try the A model forks and if my caps don't fit I'll just buy old style fork caps. I put the tapered steering bearings in and they raised the top triple clamp about 4mm so that would eat up some of the 3/8" extra length of the tubes.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • lemo32
  • lemo32's Avatar
Re: Fork tubes
19 Jan 2011 18:17
#423664
yeah like i said they put the bandit back in bike lmao!
  • 893cv
  • 893cv's Avatar
Re: Fork tubes
19 Jan 2011 21:22
#423734
Try these folks. They have the lowest prices I've found for OEM parts.
www.kawasakipartsnation.com/
1980 kz1000 LTD
1978 Z1R
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Fork tubes
19 Jan 2011 21:30
#423735
use some 650 forks tubes,same diameter roughly 1/2" shorter
  • tequila
  • tequila's Avatar
Re: Fork tubes
20 Jan 2011 01:47
#423752
Hallo guys. Im here also new. And i have similar problem.
I need to buy new front forks or onla tubes on my kz750b twin 1977. I found something on e bay but shipping is much more expensive than forks. can any body tell me where can i found these spare parts in europe? Thanks a lot
  • andy9802gt
Re: Fork tubes
20 Jan 2011 02:13
#423753
PLUMMEN, will my fork caps and damper rod work with those forks?
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Fork tubes
20 Jan 2011 05:25
#423774
yep B) the 900 springs will make it ride stiffer since they will be preloaded in the shorter forks B)
