hardtail choices...
- Wheels
hardtail choices...
15 Oct 2010 14:00
i'm researching hardtails and I have found these:
1. www.thefactorymetalworks.com/ProductDeta...uctCode=HT-UNIVERSAL
2. www.tcbroschoppers.com/store/index.php?m...ath=8&products_id=10
3. welding current swingarm
a couple of questions... are there any other options that i haven't come across? and... those that have used one of these, can you give some tips?
thanks,
wheels
thanks,
wheels
bikes:
81 KZ550 LTD
08 R1
81 KZ550 LTD
08 R1
Re: hardtail choices...
15 Oct 2010 18:03 - 15 Oct 2010 18:07
Would google konging motorcycle frame
Lowers seat height to hardtail specs and keeps the shocks.
Which some folks consider as the best of both worlds.
Also search konging in the above search forum box.
Last edit: 15 Oct 2010 18:07 by Patton.
- Wheels
15 Oct 2010 19:19
Patton wrote:
thanks Patton... appreciate the info. yeah, i think i've already worn the search button out.
bikes:
81 KZ550 LTD
08 R1
81 KZ550 LTD
08 R1
- Wheels
15 Oct 2010 19:35
for other newb's like me that have no idea what 'Konging' is... here is a step by step write up:
www.hondachopper.com/garage/konging/konging.html
thanks again Patton.
bikes:
81 KZ550 LTD
08 R1
81 KZ550 LTD
08 R1
- lobstermobster
17 Oct 2010 00:37
Also, check out bratstyle.com. It's all in Japanese so lucky you if you can read it, but its all bobber style chops but keep the rear shocks. Probably similar to konging or w.e but bratstyle is sick. Alot of people have used tc bros and like them. With those you will have to make a jig and what not to do it right. Def don't think you should weld onto the swingarm, that just looks lazy and half assed most of the time. Also check out chopcult.com sick site/forum with all your custom build shit you could ever want. Everyone is super cool over there. Alot of the guys here swear by keeping a bile stock(which is fine) but you might find more of what you want as far as custom stuff over there.
1981 kz650 w/ flux capacitor
- H1Vindicator
Last edit: 21 Feb 2013 02:16 by H1Vindicator.
- 55fbomb
17 Oct 2010 08:32
Does that one kit actually say bolt on hardtail? lol.
1974 CB750
1975 CB750
197? CB750 mutt
1977 KZ1000
1975 CB750
197? CB750 mutt
1977 KZ1000
- Wheels
17 Oct 2010 15:47
thanks for the input/info...
lobster, just signed up over at chopcult.. thanks.
bikes:
81 KZ550 LTD
08 R1
81 KZ550 LTD
08 R1
- hocbj23
17 Oct 2010 18:38
also try "Do the Ton.com".They have a chopper and bratstlye section that may be of help.bj
- 78kztwin
19 Oct 2010 13:03
I bought the universal kit from tc brothers choppers for my 78 750b3. Haven't set it up yet but aside from setting the lines straight and measuring, it seems pretty straight forward. Should do it in a couple weeks and I'll get back with you.
78 kz 750 twin work in progress
- Wheels
19 Oct 2010 13:09
let us know how it turns out 78kz... that's probably the route i'll go. just not sure yet...
bikes:
81 KZ550 LTD
08 R1
81 KZ550 LTD
08 R1
- Bdog
- Sweep the leg johnny!!!
19 Oct 2010 13:17
The bolt on hardtail are for Triumphs and BSAs, not Kawis.
Bdog
Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
