kz to zx7 conversion part1
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: kz to zx7 conversion part1
13 Oct 2006 14:04
#84007
Is the 650 stem the same as the kz900?when looking for forks do I need to pay atention to the length of dif. years & models or are they all about the same?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 77KZ650
  • 77KZ650's Avatar
14 Oct 2006 11:42
#84260
Feel better soon! thx for the update. as for the 6 inch rim, you should only need a 3/8 offset front sprocket to get it to line up, and no machining
not sure if the 650 stem and the 900 are the same, but I really dont think it matters, you are just using your original stem in the new triples
07 MDP Rookie of the Year
  • galaxian
  • galaxian's Avatar Topic Author
16 Oct 2006 06:07
#84653
77kz650- I just dont see mathematically how that is. If you have done this i have questions.
1. is the rear rim 6"?
2. Does the chain clear the frame and by how much?
I guess i dont see how and here is a quick diagram of what i am talking about
Post edited by: galaxian, at: 2006/10/16 09:09
1977 KZ1000A1, 1979 KZ650 C3
  • galaxian
16 Oct 2006 06:14
#84656
one more try
  • 77KZ650
  • 77KZ650's Avatar
16 Oct 2006 09:40
#84693
yes my zx7 wheel is 6 inch with a 190 tire. I did some research on here awhile back have a look here Intimida2or has a 5.5 zx7 rim with a 190 tire and is using 3/8 offset. when I bid on my zx7 wheel, i assumed that it was going to be 5.5 aswell, but it might be newer than his as its a 6. To make sure it was going to fit, I put the lower case (motor still apart) back into the frame to do a mock up, and a 3/8 will work with my setup aswell. yes the wheel is centered in the zx636 swingarm. there is actually enough room to move the wheel over and not need an offset front sprocket, but the wheel wouldnt be centered that way
I can try to get some pics next time Im over to my dads shop to work on the bike if you want them.
Scott
Post edited by: 77KZ650, at: 2006/10/16 13:52
  • galaxian
17 Oct 2006 06:02
#84893
pics would help. I guess i just cannot see it working mathematically.
  • tw..
  • tw..'s Avatar
17 Oct 2006 07:50
#84917
If I'm not mistaken I used a 5/8 off set sprocket on my kz900 with a 5.5 inch rear rim and it worked out perfect. I did have to flatten to small sections of my frame where the chain was rubbing. I also made a couple of shims for the rear wheel and I was done.
tw
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • galaxian
17 Oct 2006 07:55
#84918
I have a feeling that the 900/1000 frames are larger and you have more clearences than the 650 frames. I could be wrong though;)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
18 Oct 2006 21:01
#85357
Do the 650's use a 530 or 630 chain? If it is 630 like the kz900 you could use a 530 and gain some clearance.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 77KZ650
  • 77KZ650's Avatar
18 Oct 2006 21:06
#85359
530, same as the zx's
  • stresser
  • stresser's Avatar
28 Jan 2007 12:53
#108776
hi galaxian did you press the stem out of the zx7 lower tree or just cut it flush? iv tryied to press mine out and it just doesnt budge any idea if its tapered ,i tought there was a tread on here about a taper in the stem but i cant find it,i tryed both directions and she wont move? any info would be great.
tony
:whistle: :whistle:
also if anyone else has any input it would be great
thanks
Post edited by: stresser, at: 2007/01/28 16:25
  • stresser
  • stresser's Avatar
28 Jan 2007 19:48
#108865
...anyone...anyone:blink: :ohmy: :( :pinch: :S
