kz to zx7 conversion part1
- galaxian
10 Apr 2006 15:58
Hello all i wanted to post some pics of the new front end going onto my kz650. I pressed out the my old stem and pressed it into a 96 zx7 triple. Actually i cut the zx7 stem and then used it as a spacer to press in the kz stem.
OD of KZ stem = ID of ZX7 stem.
Post edited by: steell, at: 2006/04/10 21:36
Post edited by: galaxian, at: 2006/04/11 09:17
Post edited by: galaxian, at: 2006/04/11 09:21
1977 KZ1000A1, 1979 KZ650 C3
- Intimida2or
Re: kz to zx7 conversion part1
10 Apr 2006 16:16
That front end is coming together well !
I need to do a similar swap for my dad's Z1 then i'll have both wheels from a ZX.
Keep up the progress!!!
- 77KZ650
10 Apr 2006 17:48
Looking good!
I might try something like that next yr
07 MDP Rookie of the Year
- Sandy
- Fly High,Tony
10 Apr 2006 21:25
Lookin GOOD!!
Your calipers...polished,or did You get them chromed?...I like em!
I have the same ones for My ZRX conversion,which I'll be starting on,after this season...still working on getting a few more parts...
1977 KZ1000 A-1
- indykaw77
11 Apr 2006 03:34
Way cool....keep them "How-to's" and pics coming!!
Kawasaki Motorcycles...because cars lean th wrong way!
- galaxian
11 Apr 2006 06:09
Last night i welded a bead between ZX7 and KZ stem as an added bit of security.
The calipers are unfortunatly chromed. They came with the forks so i had no say in what they look like. It is a little too much bling for my taste.
The head bearings should be in within a few days and i will test fit these on the frame i have laying around.
Once again Z1 enterpries come through.
The rear is a whole other issue at the moment seeing as i am determined to fit a 6" wide rear wheel into a space that is not designed for such. As a side note for those KZ650 guys thinking about doing this conversion. A 4.5" rim will fit into a Suzuki GS swingarm with no problems. If you want a wider wheel to run a wider tire you will need a swingarm upgrade and an offset sproket. I will post more pics of these later.
I will post more pics as the parts come in.
Post edited by: galaxian, at: 2006/04/11 09:24
- elcid
25 Apr 2006 10:56
can you post another photo of the fork on the bike? The one above is gone...
- galaxian
26 Apr 2006 06:53
I havent installed it yet due to the fact that i still have to machine the rear parts to get them to fit. Otherwise this is ready to be bolted on.
- Intimida2or
- 77KZ650
09 Oct 2006 20:37
There must be a ton of progress on this by now. Anything new you would like to share Galaxian? Im bidding on a ZX7 front end right now, and It would be great if you could give me any tips specific to this particulr conversion:)
Scott
Scott
- galaxian
12 Oct 2006 08:44
Well i decided to fit a 4.5" rim in the rear instead of the 6" i had planned. The reason is i dont thing the sprocket carrirer will be strong enough with that much material removed so as to fit the wheel. The front end is the easy part the rear isnt too bad but some machining is required.
To fit a 4.5" rim you will only need to machine 1/2" of the carrier and no front offset sprocket will be needed. That is why i chose this route. I will try to post pics of the machining as i do this. I have been somwhat sick for the past few months and so no progress has been made.
- Sandy
- Fly High,Tony
12 Oct 2006 19:03
Thanks for the update,Galaxian.
I'm doing something similar,but I'll be using ZRX parts,when I do it.
Right on,Bud...keep Us informed.
1977 KZ1000 A-1
